Home Page
Build a encapsulated load resistor.
Page 1 | 2 | 3 | 4
Email     Bookmark     Print
Buliding a 300 200 watt dump load
A dump load is used to drain
off excess power. This design
uses a few 50watt light bulbs and
with some parts from the junk pile,
shouldn't cost more that $20 to build
One of our forum members has put together this excelent article on building high power encapsualted resistors from common heater elements. Encapsulated resistors can disipate a lot of heat without destroying themselves, making them perfect for dump loads.
Easy to build encapsulated load resistors.
By Pete (downwind).
This was a project to show how old electrical elements from stove ovens, dishwashers and clothes dryers etc. can be used to fabricate good quality load resistors. It is extremely easy and in most cases free of charge (if you can find one in council hard rubbish or hanging in the back shed).
For many years now I have cruised the RE sites reading with much enjoyment the ideas and projects of so many others, but every time the question is asked if one can use water heater elements or other enclosed electrical elements, the short answer is always “NO” with a lengthy explanation why.
I disagree with the “NO” and would like to show a “YES” they can be used easily and how to do it. As yet i have not seen where this has been done, but am sure others have done similar but not told the rest of us.
So it was out to the shed to test the idea.
First find an element, the longer the overall length the better. This one was rated at 2000 watts (2Kw) at 240 volts. Or 8.3 amp.
There is a steel conductor inserted in each end that the terminals attach to. The conductor goes approx 75mm (3”) into the element . It can be easy checked with a magnet where it stops, as the element itself is non magnetic. The section with the steel conductor in it is of no use.
Measure the overall lineal length of the element between the two steel conductors each end. (use a piece of string) The element above gave me 1100mm of element between the conductors.
It is better to calculate the amps per resistor lower than required, as the resistance can be lowered later to increase the amps but cannot be done vice versa.
If we have an element rated at 2400 watts for 240 volts, and wish to use it with 24 volts then we could cut it into 10 sections and have 10 x 240 watt resistors. I would recommend that the resistors be only made to half their rated wattage to keep the heat per resistor lower and use 2 in parallel to gain the same wattage. For this reason we would cut the element into 5 sections only, and get a total of 1200 watts with 5 resistors in parallel (5 amp per resistor) Under full rated load (10 amp) they will glow red as they would normally if used in your oven. For a element of 2000 watts at 240 volts, with a total length of 1100mm
watts = volts squared divided by ohms
therefore ohms = volts squared divided by watts, so
(240 x 240) / 2000 = 28.8 ohms. (total length resistance)
You want 4 amps at 29 volts = 116 watts.
ohms = (29 x 29)/116 = 7.25 (same formula as above)
length of 29 volt resistor = total length of element x (7.25 / 28.8)
which is total length x 0.251 or approx 1/4 of the total length.
For different wattage and length elements, substitute actual values in the above formulae.
Next is to cut the element each end, where the steel conductor stops. This is easy done with a hacksaw and a cut made “around” the outer casing for about half the circumference, and with a gentle back and forth bending to snap the outer in half.
Gently pull some of the nichrome wire out of the mineral lining by about 20mm. Cut the nichrome wire so 10mm is protruding out of the element both sides. Gently straighten out the bends in the element so it is one straight length. This is easy to do by hand, then lastly, tap it straight with a rubber mallet.
Measure and mark the element into the calculated resistor lengths required. Cut element into sections with hacksaw as previous. Note keep the nichrome wire short as it gets caught in everything when working with it and can/will be stretched out longer later. This gave me 5 resistors around 220mm long.
The resistors were buffed on a wire wheel as It is intended to silver solder onto them later. At this point it is up to you, how you choose to mount them. Here is two simple examples.
Holes drilled in a ceramic floor tile for 3/16 bolts
This looked a little boring and I decided to take it further to show what can be done and how easy it is to do. The next intension was to mount the resistors in a old atx psu casing. The fan was to remain, so space is tight.
Next Page.
© TheBackShed 2009
