Home Page
  Home  |  Contents  |  Forum
Print
Mini-Mill. Page 1 | 2 | 3
Back to Part 2 - Putting it all together
Stepper motors can come in various wire formats, from 4 wire to 8 or more wires.
Use a multimeter to determine which lead is which, then connect a couple of bridge rectifiers as shown.
As the mini windmill uses a small two blade design the RPM will be quite high ( very high! ). Therefore I would use high speed rectifiers and a smoothing capacitor to reduce electrical noise in the output.
Once you have the wind mill up and going, measure the output voltage. If you intend to run voltage sensitive devices from the windmill output, I would recommend a 5 watt zener across the output
To use the Mini Mill as a battery charger I used the following circuit. You may need to adjust the resistance or R1 to achieve a good charging current based on. Charging current should be 1/10th of rated battery current for 10 hours to achieve best battery life.
Further Suggestions.
Garden lights.
Change the double AA battery holder for a quad C battery holder to give you 6 volts worth of Nicad batteries. Design a circuit to using a light dependant resistor to turn on a mini relay and mount that on the windmill along with a 6 volt lamp ( as used in a torch ). During the day the windmill charges the nicad batteries, and at night the lamp turns on to light up the area.
