Local Time 22:17 20 Nov 2026 Privacy Policy
Forum Index : Solar : Disabled Scooter Motor
joyt12k
Posted: 10:53am 26 May 2009
I have'nt as yet got a F&P, however I picked up a DC motor the other day. The make is Fortress Scientific,
24volts, 15amps, 172rpm through a gearbox.
I think i've stuffed up, I machined away the gearbox part, and have worked out the rpm is in the region of
3243rpm, now theres no way the wind will spin it at that speed, just a quick spin with the fingers, light up a 6volt bulb, and a 2800rpm electric drill attached
produces 19volts with a multimeter. Any information would be appreciated.
jasmine
Posted: 11:23am 26 May 2009
Hi Jasmine
Yeah sounds like you stuffed it up.
But dont worry, we've all done that at one time or another. Without the gearbox its only usefull as a motor, put it in the spare parts bin and it will get used for something one day.
I have a few 24v Scoota motors that are not any good for windmills, but I'm thinking I might make a fan. I have a burned out 240v floor fan ( like a pedistal or desk fan, but sits on the floor ), so I plan to replace the 240v motor with one of the 24v scoota motors and use it as a 24v fan for the workshop.
