Local Time 06:04 22 Sep 2026 Privacy Policy
Forum Index : Solar : Adding new solar panels to old
Tim_the_bloke
Posted: 08:45am 09 May 2010
I have been told old solar panels can limit the performance of new panels.
I am about to purchase some more solar panels to upgrade my old small off grid system. Currently I have one 80W polycrystaline panel which has been working for perhaps 15years. I am considering buying three new 80W monocrystaline panels. Can I just add them in parallel to the existing panel? Or, should I install them as a seperate bank charging a seperate bank of batteries?
I intend to replace batteries as well. I know new batteries should not be added to an old battery bank.
Posted: 09:05am 09 May 2010
Hi Tim
Yes they will work fine connected in parallel. Its when you connect them in series that you will have problems. A string of solar panels connected in series will only ever supply as much current as the weakest panel.
Same with shadows on a panel, if you have one cell shaded, say from a big leaf, then the whole panel might as well be in the shade. Thats why its important to wash off bird poo.
Tim_the_bloke
Posted: 09:10am 09 May 2010
Good. That makes installation much easier. Thanks for the advice.
KarlJ
Posted: 09:14am 09 May 2010
Oh make sure the open circuit voltages are in the ball park with each other.
if old panels are 24V and new panels 36V then no point putting the old panels in the mix as they will contribute nothing.
Karl
