Local Time 22:41 20 Nov 2026 Privacy Policy
Forum Index : Solar : batteries and lights?
readyakira
Posted: 04:28pm 10 May 2010
Few questions again..... anyone know a cheap place in the states to get 14v cfl lighting? oh, and as far as battery discharge goes.... how do you measure that and what is the math used? for example if I have a 12v battery with these specs:
Battery BCI # : 27DCM
Battery CA @ 32 Degrees F : 715
Battery CCA @ 0 Degrees F : 575
Battery Height : 9 3/8"
Battery Length : 12 1/2"
Battery Posts Type : Top Post/Stud
Battery Reserve Capacity : 200
Battery Voltage : 12 v
Battery Warranty in Months : 36
Battery Weight : 53 lbs
Battery Width : 6 3/4"
Wet or Dry : Wet
Then how do I know when it is discharge to the point I need to stop drawing from it? And cycle life. Say it has a 200 charge cycle life. how do you figure that if you are charging all day? I aquired another 45w in solar toys... bringing me to a measly 60w but I am looking to buy some real panels at about $2.25us per watt. They are 175w evergreen panels.
Don't you think Free/Renewable energy should be mandatory in new buildings?
VK4AYQ
Posted: 05:08am 11 May 2010
Hi there
Your battery would be around a 60 ah rating from your description, service life depends how you look after it don't discharge below 11.5 volts also when you get your bigger panels you will need a regulator to stop overcharging it as that will destroy it also. If you look after it it should last 1000 + charge cycles if you don't it wont last out the summer, Do not run it flat as automotive batteries die very quickly if discharged below 50% capacity, fir a desulphator in your systen to keep it in the best condition possible.
The battery is approx 720 watt hours divided by 2 allowing 360 watt hours for lighting and led and cfl work at 5 to 10 watt hours so should keep you in lighting.
The cheapest source of lights is ebay china both cfl and led lights I have found them very reliable and quick delivery.
All the best
Bob
Foolin Around
