Local Time 22:51 20 Nov 2026 Privacy Policy
Forum Index : Solar : batteries in parrell
bobt
Posted: 02:03am 01 Jun 2010
g'day everyone,
Im just about to buy 2 new 95a/h deep cycle batteries and i want to put them
into parrell wiring from the regulator.
1)will my 80 watt solar panels charge both batteries at the same time in parrell?
or
2)do i have to separate both batteries to recharge individually?
3)would a new regulator with mppt be better to charge both batteries
at the same time? over the basic regulator that came with my system ?
cheers bob
VK4AYQ
Posted: 06:38am 01 Jun 2010
Hi Bob
I am assuming that the batteries are the same.
1. yes
2. no
3. A MPPT regulator will give you more charge from your panel but your basic regulator will work OK but MPPT will put 20-30 percent more into the battery say from 4.5 amps to 6 amps.
If you go to the expense of getting a MPPT regulator be sure to get one with extra capacity so you can expand your system later on.
All the best
Bob
Foolin Around
bobt
Posted: 06:47am 02 Jun 2010
g'day everyone,
thanks for your reply vk4ayq,
I wanted to be sure before going ahead with the batteries in parrell.
cheers
bobt
