Local Time 23:15 20 Nov 2026 Privacy Policy
Forum Index : Solar : Sterling engine help please
Todax
Posted: 01:32pm 26 Nov 2010
Experimenting with this engine for solar use, but I would like to switch to a beta style engine. I've reviewed many drawings and can't quite figure out the displacer arm attachment. Does it ride through the piston shaft, along side it, or what? Any help would be greatly appreciated.
Posted: 10:26pm 26 Nov 2010
Hi Todax
The Beta type has the displacer in the same cavity as the power piston, and its driven by a shaft that goes up the center of the piston. Its probably one of the hardest to make, but its also the most compact.
http://en.wikipedia.org/wiki/Stirling_engine
I've built several Gamma's, including one LTD that would run on ice, using the room temperature as the heat source, fun stuff. I want to build a alpha type, much bigger, and use a wood stove as its heat source.
MacGyver
Posted: 11:41pm 26 Nov 2010
Todax
These type engines run on suction rather than expansion, so they are limited as to how cool you can keep one side. As soon as the hot-side and cold-side temperatures get close to each other, the thing grinds to a halt.
A "Flame Sucker" engine is a lot of fun to build and watch run, but again, it is only as efficient as it is possible to keep the finned area colder than the flame it's sucking in.
If your idea is to use concentrated solar energy to run the thing, you won't have to worry about that temperature difference as much as you will about lubrication. I built one that ran off concentrated solar once, but it didn't put out enough power to amount to much. Fun to watch run, but that's about all.
. . . . . Mac
Edited by MacGyver 2010-11-28
Copeville, Texas
Todax
Posted: 05:19pm 27 Nov 2010
Gizmo, I saw that pic and many others, but none I've found show the actual machining details. I sort of thought they worked as you stated, but working out the linkage seems to be the real trick.
Mac, I've seen those flame suckers but as well as they work, I agree I don't see any practical application.
And to both of you... since I'm a cabinet maker by trade, I always look for ways to build with my scraps. As well, I'm always telling my clients tha radius work is twice as expensive and time consuming as squared work. To that end, I'm going to work on a regular Stirling engine with mostly wood parts with squared pistons (After all, what does shape matter when it doesn't involve girls... or friction). Since I really want it more for study purposes only as a model, longevity isn't important. The idea is to find a way of making a lever style piston that would be easier to use to make multiple cylinders. Any thoughts from the wiser souls here?
Posted: 02:38pm 28 Nov 2010
Todax, I think square wooden pistons would be a first in engine design .
Let us know if it works.
Robb
Posted: 02:50am 29 Nov 2010
  Tinker said   Todax, I think square wooden pistons would be a first in engine design .
I have seen a sterling engine with a polystyrene foam piston. It was the air displacement piston and did not touch the sides of the cylinder. Once again it was only a gimmick kind of thing to play with and would run with ice or a warm kettle. Fun to see going
Todax
Posted: 03:43am 29 Nov 2010
Yeah, I'm sure it'll work. Since I'm new to the science of it all, it'll make everything easier to adjust as needed. Obviously, they'll be a metal heat plate and wire used, and in the end, it is just for use as a model to check out the workings of Rev Stirling. It'll also make it easier to test a balloon for the power piston and switch to a solid one.
I also saw many things used for the displacer. About the only truly new idea from what I see is leaving things square. I know it's not the most proficient way of doing it, but it'a the quickest and easiest for something that'll just fill a storage box very quickly.
I also expect to take a shortcut with the displacer piston. I saw one guy that used a spring wire instead of a piston rod... so why not? Hopefully, I'll have it done this week.
VK4AYQ
Posted: 03:48am 29 Nov 2010
Hi Todax
I restored one years ago, it was huge and weighed a tonne and made less than 1 horsepower, I think it was an erricksen, it was used originally to pump water but after setting fire to the farm several times they used a little diesel motor, Unless you have a thing for hot air engines you would be better to go for a solar steam setup.
All the best
Bob
Foolin Around
Todax
Posted: 04:20am 29 Nov 2010
Total nubie here. One step at a time usually works best. Once I have thorough on hands knowledge, then I'll go for the next rung. I have a goal, but I need a good base knowledge before making that leap. Getting alot of help and ideas from here though. Thanx.
VK4AYQ
Posted: 01:16pm 29 Nov 2010
Hi Todax
A friend of mine made one with volkswagon air cooled cylinders one for the hot and two for the cold, he used swinging links for the piston guides and a welded up crank shaft.
Just a suggestion
All the best
Bob
Foolin Around
