Local Time 12:42 22 Sep 2026 Privacy Policy
Forum Index : Solar : 50mm welding cable
brucedownunder2
Posted: 06:23pm 25 Jul 2012
I have scored some 50mm welding cable for my inverter..
Would anybody know of a 50mm crimp terminal that goes into a circuit breaker inlet tunnel.. I've seen them up to 16mm cable with a spade like section , but can't find listed anything for 50mm cable -you see my breakers have a max of 25mm cable entry.
can get plenty of the hole terminations.
Bruce.
Bushboy
Posted: 01:58pm 26 Jul 2012
Usually a breaker is sized with a current rating to protect the installed cable size.
For "normal" mains power distribution it would be very unusual to fit (say) a 30 Amp circuit breaker directly to a 200 Amp cable, which is why the hardware to do it would not be a commonly available off the shelf item.
What I would do, is step down the end of the 50mm cable to 16mm, crimp it, and then solder all the loose strands together and onto the crimp lug into one solid lump.
Then cover it with heat shrink.
That should work and look reasonably neat.
Oscar4u
Posted: 11:18pm 26 Jul 2012
Hello Bruce
all my welding leads are terminated with half inch copper water line. Once you have flattened the tube with the wire in it, try to fold the tube in half with a cold chissel in the vice so that the wire end of the tube looks like two U. Guaranteed not to come undone. Cheap and nasty. Best wishes
Oscar
Oscar4u - for all your rotary cowshed repairs
Privatteer
Posted: 12:03am 27 Jul 2012
You can get stalk lugs up to 630mm2. They have a solid reduced size pin at the end.
Cabac part No CS50/10 = 50mm2, with a 10mm OD pin.
The other option is reducers. Buy a 50mm to 16mm. Then crimp some 16mm2 stranded in the small end to make it a stalk lug.
Assuming of course you have access to a hydraulic hex crimper and not just a punch crimp.
brucedownunder2
Posted: 11:18am 27 Jul 2012
Thanks Crew , I have searched and come up with the above ..So have you,thanks for your efforts.
hey, this is big fella cable ,got it new, from a roll at the scrap dealers.
I have a hydraulic crimper ,so the lugs ,with all your interest, are now "not a problem".
The Tracker project moves along ,I'm half crippled with this "gout" ,but she's getting better. At the stage of drilling and fitting the side strengthening braces as Glenn suggested .
I'm not worried about time,it will get finished when the cable is finally connected ..
Thanks Crew
Bruce.
Bushboy
windlight
Posted: 07:09am 05 Aug 2012
"inlet tunnel" could not get my mind past that, what were you trying to achieve?
I must take myself out of the jungle, I must take myself out of the jungle.
Not a lot happening here in FNQ.
allan
brucedownunder2
Posted: 12:18pm 05 Aug 2012
Hi Allan, Oh, "inlet tunnel" --the clamp bit that the cable goes into --
I was lucky ,bought some large (35mm) cable pins ,so the termination problem is now solved .
Put those side braces(50x50 angle) along the long sides as Glenn suggested --that has strengthened it up a lot..
This project is taking a very long time , but you all have to understand, I'm half crippled with this bloody gout in my knees, toes and ankles. Hoping I'll improve as I get the Uric acid levels down . Reckon it's not a quick fix ..
Apart from that , I'm having a nice time putting this together, I cut ,weld, drill, cold gal ,paint and in the end it's going to be a nice jobbie.
"I gotta get out of this Jungle" ,,,gee Al I remember saying that on a mountain in PNG in 1980. the friggin helicopter could not get in to the landing pan for fog . My "Boys" and I ended up climbing DOWN the mountain to a dirt road where the chopper was waiting. only took 2 hours ,only . We fell most of the way ..
Hope you and Blondie are ok up there ..
Bruce
Bushboy
windlight
Posted: 01:41pm 07 Aug 2012
Hi Bruce, at least your project is still heading in the right direction and having seen your work I know it will be perfection.
Have you ever tried this product,
Overview
L-Glutamine is an essential amino acid that is vital to every muscle in the body and is one of the most significant building blocks in forming the proteins that preserve cellular health and tissue repair. L-Glutamine is found in most meat and fish as well as, to a small extent in vegetables and pulses.
Anyone involved in high intensity training programmes designed for muscle growth or increasing strength, are advised to use L-Glutamine as a dietary supplement to boost their intake for improved recovery.
L-Glutamine is also great for anyone undergoing training for endurance sports such as building solar panel trackers,long distance running or cycling and can help to reduce the occurrence of muscular cramps. It is also recommended for elderly people who suffer from regular muscle pain as a natural alternative.
I'm not suggesting you take up bodybuilding but you may notice an improvement from their use.
Allan
