Local Time 16:47 22 Sep 2026 Privacy Policy
Forum Index : Solar : I need a new pump for my Solar Hot Water
larny
Posted: 05:37pm 20 Jan 2015
I bought a Chromagen Solar Hot Water system about 10 years ago.
About 4 years ago, I discovered that the pump was not working. I opened it up & found it had rusted inside.
So I went to Chromagen & bought a new one. It was a different brand to the old one so I hoped it would be of better quality & more reliable.
But recently, I discovered it is faulty. It looks as though rain water has leaked into the top of the pump as there is burnt wiring under the top cover.
Does anyone know where I can buy a better pump?
Any advice will be appreciated.
Posted: 05:49pm 20 Jan 2015
I would suggest you do more to protect the pump. If the first pump lasted 6 years, and the 2nd lasted 4 years, then thats not a bad life, especially if they are exposed to rain water.
Can you make a cover for the pumps.
larny
Posted: 07:39pm 20 Jan 2015
  Gizmo said   I would suggest you do more to protect the pump. If the first pump lasted 6 years, and the 2nd lasted 4 years, then thats not a bad life, especially if they are exposed to rain water.
Thanks Glenn,
That is what I had in mind. I can & will make a cover.
But first I thought I would ask the question re better pumps & alternative sources of supply.
Actually, I don't know how long they lasted. I don't know how long they were faulty before I investigated.
Len
VK4AYQ
Posted: 01:45am 21 Jan 2015
Hi Larney
There are a few good 12 volt circulation pumps available on fleabay all plastic and ceramic shafts so no corrosion 15 to 20 watts so will run off a small 12 volt panel and a few caps.
All the best
Bob
Foolin Around
larny
Posted: 11:33am 21 Jan 2015
  VK4AYQ said   Hi Larney
All the best
Bob
Thanks Bob,
I forgot to mention that my pump is 240 VAC.
But I assume that fleabay will have those also. So I'll have a look.
Alternatively, as a last resort, I could power a 12 VDC one with a transformer & rectifier bridge.
Len
VK4AYQ
Posted: 11:52am 21 Jan 2015
Hi Len
There are 240 volt ones on Fleabay about $90 though the idea I had was to use a 12 volt one and a small solar panel and that switches on when the sun shines and does away with all the unreliable switching gear for the 240 volt one and the power they use
mine uses about a KW a day and is unreliable anyway.
All the best
Bob
Foolin Around
Georgen
Posted: 04:16pm 21 Jan 2015
  VK4AYQ said   ...
There are a few good 12 volt circulation pumps available on fleabay all plastic and ceramic shafts so no corrosion 15 to 20 watts so will run off a small 12 volt panel and a few caps. ...Bob
Sorry to bump in 240V pump thread.
Bob,
Where could I find detailed info on 12V pump, caps and solar panel arrangement?
(especially caps as I think of reticulating water in garden watering system)
Probably new thread?
George
VK4AYQ
Posted: 05:38pm 21 Jan 2015
Hi George
The circulation pumps are not suitable for garden type activity as they are too low capacity and head "pressure"
I used a flow pump for garden work about 17 LTR minute 12 volt with pressure switch built in, they draw around 6 amps and will run off a 80 watt solar panel, all you need to do is to put some caps across the panel to hold a bit of electricity to help them start the last ones I used where 10000UF 35 volt four of them they where in my junk box, any large capacity on will work but voltage needs to be high as the panel can do over 20 volts on a sunny day. You can add a small battery motorbike type but then you need a regulator to stop cooking the battery, but it will give a bit of use when the sun is hiding.
All the best
Bob
Foolin Around
