Local Time 11:14 22 Sep 2026 Privacy Policy
Forum Index : Solar : Solar Hot Water
VK6MRG
Posted: 06:27pm 29 Dec 2016
Hello everyone.
Firstly, hoping that everyone had a Merry Christmas and that you all have a fantastic and safe New Year!
I've been following Chris from Justin Case YouTube channel and he has been showing off a product that he is trialing that is a MPPT controller for a standard electric hot water service.
Product website here .
YouTube link here .
Just found the price of the product and it's not cheap! But I think it will work well for my place.... Just need to save up for it!
Matthew
VK6MRG & VK3MGREdited by VK6MRG 2016-12-31
yahoo2
Posted: 09:05pm 30 Dec 2016
I think this is the original
solar hybrid hot water booster
VK6MRG
Posted: 09:30pm 30 Dec 2016
Hi Yahoo2,
WOW, big difference in price!
Would be good to get one to test.
Matthew
VK6MRG & VK3MGR
Tim_the_bloke
Posted: 09:26pm 31 Dec 2016
Interesting. I hope more such products will soon appear on the Australian market. Today (01-01-2017) is the first day thousands of households in NSW lose their solar feed in tariff subsidy, meaning a likely 90% drop in price the electricity sold to the grid from roof top solar panels. So, there is now a real market for such gadgets.
Presumably this gadget feeds DC into the water tank heater element. I note this gadget uses the hot water tank's existing mechanical thermostat. I wonder what happens to such a thermostat switching off DC current. Will there be a flash each time it switches off?Edited by Tim_the_bloke 2017-01-02
Madness
Posted: 09:48pm 31 Dec 2016
  Tim_the_bloke said   I wonder what happens to such a thermostat switching off DC current. Will there be a flash each time it switches off?
Only the first couple times if it even survives the first switch off. Those thermostats are not capable of switching high current DC, first time it turns off under load will be like striking an arc with a welder.
A couple MOSFETs controlled by the thermostat would be a far better solution.
VK6MRG
Posted: 09:49pm 31 Dec 2016
Hi Tim,
From what I have read the unit puts out modified square wave so like an old school inverter output not straight DC.
Matthew
VK6MRG & VK3MGR
Madness
Posted: 10:40pm 31 Dec 2016
If you already have grid tie solar the only hardware you need is a timer to turn on the power to the hot water system during the middle of the day when there is sufficient solar power.
Tim_the_bloke
Posted: 11:01am 04 Jan 2017
  Madness said   If you already have grid tie solar the only hardware you need is a timer to turn on the power to the hot water system during the middle of the day when there is sufficient solar power.
Where in the circuit would you put the timer?
1: Divert the inveter output to the hot water tank? Would not disconnecting the inverter from the grid stop it working? Perhaps leave the inverter grid connected but use the power before the feed in meter. Would this cause problems? Why have a timer?
2: Between the main supply and the hot water tank's secondary element? This would bypass the off peak switch without interfering with it.
Mmm, as I type I reckon option 2 would work well for tanks with multiple elements.
Madness
Posted: 12:11pm 04 Jan 2017
Just connect it to your AC mains and set the timer to work in the hours where there is sufficient sun. If you have off peak you could use a contactor to disconnect that and connect to the same circuit as your Inverter is on.
No need to disconnect the Inverter from the grid, when the hot water is up to temperature it will turn off and all excess power will go back to the grid.
flc1
Posted: 06:21pm 06 Jan 2017
Gday Maddness, we are useing the timer switch that you decribe ,it works well, we just set it to come on during middle of the day for a hour or two, when theres max solar output.
This time of year(summer) the hotwater cylinder and timer are switched off because our solar water is doing the heating.
Fred
Madness
Posted: 08:05pm 06 Jan 2017
If the water is hot enough the thermostat should be off so anyway. My charge controllers on my off grid solar has a function called waste not which controls a solid state relay to connect AC power from the inverter. Instead of reducing power as the batteries get to the absorb voltage it diverts the excess power to the solar hot water system.
However with plenty of sun the thermostat is usually off by the time the batteries reach absorption and therefore no power is used by the hot water heater.
When we build a new house shortly I am wondering if I will even bother with solar hot water panels and just run it all from solar PV with a coil on the back of a wood heater as a booster in very cloudy weather.Edited by Madness 2017-01-08
flc1
Posted: 09:36pm 06 Jan 2017
Yea that sounds like a good system. The one thing we don't have is a wetback on our fire, they are brilliant, I was thinking of adding one next year.
The fire is nearly 10 meters from the cylinder,but its below the cylinder so with insulation on the pipes it should work fine.
Madness
Posted: 09:50pm 06 Jan 2017
You can always add a circulation pump if needed, I have built my own controller using and Arduino for my solar HW. It would work just as well on your fire if needed.
flc1
Posted: 10:13pm 06 Jan 2017
yep, good idea,thanks
