Local Time 21:49 20 Nov 2026 Privacy Policy
Forum Index : Solar : DIY Solar thermal electricty generation
Jon Bennett
Posted: 11:46pm 18 Mar 2008
Hi Has anyone played with this sort of thing?
Solar Turbine Group
Quote from Article on Popular mechanics website;
"The Solar Turbine Group (STG) is taking an entirely different approach, scaling its equipment way down so that it can be installed in remote locations. Orosz and three partners recently spent a year in the Lesotho mountains working with locals to install a prototype solar turbine at a remote girls’ school.
They kept prices low by using junk auto parts. The ORC’s turbines are made from a salvaged turbo charger, which is coupled to an alternator to create electricity. A radiator serves as the engine’s condenser, cooling the refrigerant before a power-steering pump returns the fluid to the boiler."
Other articles say that they are using an Auto Air Conditioner Compressor as the motor rather than a than a turbocharger.
YouTube Clip shows something that looks more like an AC compressor linked to the alternator at about 35 seconds.
regards
jonEdited by Jon Bennett 2008-03-22
GWatPE
Posted: 03:22am 19 Mar 2008
Hi Jon,
I played with this type of system in the late 70's. This is a quite simple process. I bypassed the heat exchanger they mention between the glycol and the refrigerant. I pumped the condensed refrigerant[NH3] to the top of an evaporator. Heat was absorbed directly into the refrigerant to form the vapour. Some superheating was achieved in the design.
The efficiency is determined by the relative temperature difference between the heated vapour and the condensate in degrees Kelvin.
The Example you have given has an approximate maximum efficiency of 30% on a temperature basis. Of course there will be losses in the heat exchangers and the turbine and the generator and plumbing etc. The waste heat recovery to heat water, offsets some of these losses.
The choice of working liquid is important. Best to have high specific heat, to reduce pumping losses. Lubrication of the turbine and condensate pump can be an issue. Hermetic sealed working fluid path is critical if using halogen type refrigerants.
I think that solar panels for water and solar voltaic panels for electricity offer a better small scale option.
Good luck if you still persue a Rankine system.
cheers, Gordon.
become more energy aware
Jon Bennett
Posted: 08:15pm 20 Mar 2008
Thanks Gordon
At a bit of a loss to a couple parts;
1. When the working liquid is heated it creates high pressure which then has a pressure/heat drop in the motor, further Pressure/heat in secondary energy system (hot water etc). You then have to pump the working fluid back against the pressure created in the heating process, doesn't that chew a lot of energy up?
2. What is the advantage of the further cooling after energy is used, I'm guessing it is to make the working fluid as dense as possible but I can't quite see the upside when you are just going to need to add nmore energy to re-exapand/heat it again.
I gues any pics or drawings of the system that you played with would be out of the question.
regards
GWatPE
Posted: 10:55pm 20 Mar 2008
Hi Jon,
you need to understand thermodynamics and how work can be done by a fluid using transitions of state.
1. liquid is heated to form a vapour. This absorbing of energy occurs in the evaporator.
2. The vapour passes through the turbine where energy is extracted as electricity. Work is done by the pressure drop. The vapour then has to be condensed to maintain the pressure drop. This happens in the condenser. The liquid pump completes the cycle by returning the condensate back to the evaporator.
This is pretty much simplified. This is not really in the scope of DIY. I would suggest studying the principles and getting some local expertise from a university if you plan on continuing.
cheers, Gordon.
