Local Time 07:06 28 Sep 2026 Privacy Policy
Forum Index : Other Stuff : Hakko soldering station problem
renewableMark
Posted: 09:26am 31 Mar 2018
Hey fellas, I'm having a problem with my hakko solder station, it appears to have no temp control.
Seller is just stuffing me around, and asks for videos which I have done on youtube, but he said that the chinese can't access youtube.
Just wondering if someone has had this problem and if there is an easy fix.
vid
Cheers Caveman Mark
Off grid eastern Melb
Posted: 09:54am 31 Mar 2018
Bugger me, I'v never seen one that hot.
Perhaps they wired up the Trim pot incorrectly?
Other brands I have used don't have a temperature sensor, just current control. Edited by Revlac 2018-04-01
Cheers Aaron
Off The Grid
renewableMark
Posted: 10:59am 31 Mar 2018
Well it did work initially, so there appears to be a fault generated after manufacture, not a mistake at the factory.
How do these little sh*ts measure the temp?
In the pencil?
Cheers Caveman Mark
Posted: 01:29pm 31 Mar 2018
Nothing in my pencil
Ok I see 5 wires.
2 would be the heating element
2 likely to be the temp sense
the other???
Would check the resistance between each see if any is open circuit, obviously the heater isn't.
Perhaps the temp sensor is burnt?
And see it someone els with the same type of unit gets the same readings.
But what do I know?
Cheers Aaron
Off The Grid
renewableMark
Posted: 09:15pm 31 Mar 2018
I'm suspecting it's something in the box as three different pencils do the same thing.
Cheers Caveman Mark
Madness
Posted: 10:02pm 31 Mar 2018
Hi Mark,
The LED should start blinking when it gets to the correct temperature and should never get anywhere near red hot.
Plenty of circuit diagrams online if you search Hakko 936 Revlac is right about 4 wires other is ground.
Could either be a problem with the temperature sensing circuit or the SCR (I think) is short circuit. You should be able to measure a change in resistance of the sensor as it heats up.
A replacement PCB is only $384, probably worth ordering one regardless of whether you get a result from the seller.
It is worth getting spare heaters and tips while you are at it, that tip that has got red hot probably won't last long.Edited by Madness 2018-04-02
brucedownunder2
Posted: 11:27pm 31 Mar 2018
That replacement PCB is only about $3 ,if I see the correct price.
I've been scratching my head about your problem also , gee, that iron ia red hot . must be the sensing controller ,for sure ..
I allways remember my solder station --I was on jury service once and with the cheque they sent me ,I walked into Dick Smith store and bought my solder station .
So, how about that -nice bit of bs for a sunday morning ,eh?
Bruce -what a boofhead.
Bushboy
renewableMark
Posted: 11:57pm 31 Mar 2018
Haha there is an easy fix, thanks Mad.
I won't bother with seller and just get that part.
Cheers.
Cheers Caveman Mark
Madness
Posted: 12:20am 01 Apr 2018
Sorry I left out the dot $3.84 AUD for the PCB posted.
I would still stick it up the seller, I have never had Aliexpress refuse at least a partial refund, usually, the seller comes to the party.Edited by Madness 2018-04-02
powerednut
Posted: 08:26am 23 Apr 2018
yeah, not being able to access youtube is bullsh*t. I had issue with an aliexpress order and they wanted a video. Posted it on youtube and got a partial refund (which is what I was after).
Boppa
Posted: 09:18am 23 Apr 2018
  Madness said   Sorry I left out the dot $3.84 AUD for the PCB posted.
I was just about to ask, I bought my entire station for under $30, $384 for the pcb only??? wow somebodies making a markup....
who are the other 22 people that saw it lol
