Local Time 10:42 14 Nov 2026 Privacy Policy
Forum Index : Other Stuff : gCncCam - the missing link
vasi
Posted: 08:32pm 10 Mar 2009
For a Win98/DOS machine used for CNC we have a complete set of software. By example, we can use a CAD (any) software for generating a .dxf file, then, converting it to G-Code for TurboCNC with the help of ACE, a g-code converter.
For Linux, we have QCad for 2D sketches saved as .dxf files and EMC2. No ACE like converter unless is ported to Linux from sources. But I found recently the missing program.
Is about gCncCam, an open source project designed to work with QCad and EMC2.
[quote=gCncCam]
This release can read DXF-Files and GERBER NC-Files (Drill-Files) and convert them to
G-Code (RS-274) NC-Files
It is tested with QCad for creating DXF-Files. The CNC-Code is tested on EMC2 CNC[/quote]
The software was tested under Linux Debian Etch and Linux Ubuntu 6.06 (is working also in 8.10).
P.S. I don't know where to post this: under this forum or "My 2 cents" forum ...Edited by vasi 2009-03-12
Elvish name: Mablung Miriel
Beyound Arduino Lang
