Local Time 10:42 14 Nov 2026 Privacy Policy
Forum Index : Other Stuff : Making your own armature?
stevet47
Posted: 01:33pm 06 Apr 2009
How would one go about making my own armature? I want to experiment
with making a BLDC motor, and want to make my own armature. Is there any
way to do with without casting? I was maybe thinking cutting several thinner
armature-shaped pieces out, then stacking them to get the thickness I
need.
Also, what differences would I see between running a dual stator like some
of you are doing with F&P's versus one larger stator that would equal the
size of the 2 combined?
Also, is there a formula or something I can use to figure out number of
windings, wire thickness, etc?
