Local Time 06:42 29 Sep 2026 Privacy Policy
Forum Index : Other Stuff : Need Help with port setup with kcam4
AMACK
Posted: 12:26pm 13 Jul 2009
I can not get KCAM4 to work. I have a KTA 205 brake out from Ocean electronics with 3 KTA 236 drivers. I can get it all to work with Mach3 but can not get it to go with KCAM4.. The only thing I can get to work is the two relays.. I think I need some help with the Bit and Pin set up.. Can someone give me a hand with the pin and port set up..
Thanks Andy..
*Note to self
1. Make it thick
2.Make it heavy.
Posted: 12:39pm 13 Jul 2009
Hi Andy
Can you get any activity from the stepper motors, even if its not what you expected? Also, what stepper driver circuit boards are you using?
I've used KCam before, its a neat little package but I had problems with it importing DXF files, it didn't understand polylines very well. I think thats been finxed in later versions. I did write a DXF to GCode parser if your interested.
AMACK
Posted: 08:22am 16 Jul 2009
I can not get any movement at all from the steppers, the only thing I can get to work is the relays. I have not got around to importing files yet as I can not get the steppers to move.. In the pin and port set up the relays use 38B port config and the rest use 387. All else failed so I read the instruction book but there is not much detail about port and pin set up. The brake out board I have uses pin 2 for Y step 3 for Y direction and so on. I have set these to all ther correct locations but it still will not work. I can get Mack3 to work well with the port set up I used?????
If you have any more info on Kcam4 eg.. pin and port info that would be good..
Andy.
*Note to self
1. Make it thick
2.Make it heavy.
