Local Time 04:53 29 Sep 2026 Privacy Policy
Forum Index : Other Stuff : coil winding
brucedownunder2
Posted: 07:17am 23 Mar 2010
had ago at winding a radio coil.
Bushboy
Posted: 07:42am 23 Mar 2010
Nice job Bruce. Whats it for, a crystal set?
I built a crystal set a couple of years ago, just for fun. I'll take a photo but its packed away. I still remember my first crystal set I had when I was a child.
GWatPE
Posted: 09:35pm 23 Mar 2010
Hi Bruce,
You may ge able to wind the wire more accurately by first cutting a thread slot into the former first. I am not sure if your lathe has thread cutting facilities.
Gordon.
become more energy aware
Posted: 10:13pm 23 Mar 2010
I used to feed a length of string beside the wire, to give a even spacing. Then unwind the string once the wire was secured. A little varnish will hold it all in place.
Building a crystal set is one future project I have for thebackshed. Its kind of a renewable project , using radio waves instead of solar or wind.
dwyer
Posted: 10:43pm 23 Mar 2010
Good on you Bruce
I did build crystal set when l was 12 years old using war aircraft headphone that around 1958 using wireless gang, cardboard tube,and brought back lovely memory at this time my hearing was good and now l am deaf with 80% loss and can't hear my own voice think getting Cochlear implant so yes Glenn let have new kind of project bulding a crystal set
Dwyer
Downwind
Posted: 02:32am 24 Mar 2010
I to had built one back in high school, I remember winding the wire around a piece of PVC pipe, we put a twist in the wire every so many turns to give different tap points for the coil.
I lived in a country area then and there was only 1 station strong enough in signal to be picked up. ABC i think it was.
The Germanium diodes are getting hard to find nowdays and not many places stock them.
I was told recently that germanium diodes are no longer made anywhere, and its only the stock that is remaining thoughout the world.
I understand they have not been produced for over 10 years now.
I had required one for a different project recently and had to look hard to locate some.
Pete.
Sometimes it just works
