Local Time 11:38 14 Nov 2026 Privacy Policy
Forum Index : Other Stuff : Laptop Computer Help
MacGyver
Posted: 04:16pm 27 May 2010
Calling on the collective genius here; my MacBook laptop computer's "back-light" (LED?) failed and I have to use a flashlight to barely see what's on the screen.
Anyone know a quick fix other than a new laptop?
This happened when it was new, right out of the box and they replaced it free, saying this happens only once in a zillion. This is the SECOND TIME for me. The odds of that happening are something on the order of winnind the lottery twice in a row. Maybe I should buy a lottery ticket, eh?
. . . . . Mac
Copeville, Texas
GreenD88
Posted: 12:57am 28 May 2010
First you need to check the cable going to the backlight might just be a loose wire when they installed the new light. But a new light only costs around $10 on ebay about $100 for a new screen. Type Macbook and Model# and Backlight fix or repair in google you should find plenty of hits.
PC's are better ;pEdited by GreenD88 2010-05-29
Licensed Master Plumber / EPA 608 Universal License / 410a Safety Certified / Medical Gas Brazer/Installer
vasi
Posted: 03:42am 28 May 2010
  MacGyver said  This happened when it was new, right out of the box and they replaced it free, saying this happens only once in a zillion. This is the SECOND TIME for me.
Maybe things changed when they switched to Intel processors?
http://www.neilturner.me.uk/2009/01/18/fixing_your_macbook_s cree.html
VasiEdited by vasi 2010-05-29
Elvish name: Mablung Miriel
Beyound Arduino Lang
MacGyver
Posted: 06:09am 28 May 2010
vasi
I owe you a Coke!
It worked for a second or two after I turned it off, removed the battery, held down the start button, then replaced the battery and re-booted. Thanks for your wisdom; you likely saved me pulling the rest of my hair out!
I noticed that my energy setting was 0%. I haven't used the computer for a day and the battery is all but whacked. I'll keep fooling around with it and maybe even pop for a new battery, if leaving it on the charger all night does the trick. I'm hoping it'll work long enough for me to scrape all the information off. I have my business on the silly thing and even though I have everything backed up, it'd be nice to make a clean break.
Thanks again.
. . . . . Mac
Copeville, Texas
GreenD88
Posted: 10:08am 28 May 2010
Most laptops also have a VGA out port that will allow you to hook it up to an external monitor or one of those fancy new tv's. :)
MacGyver
Posted: 03:29pm 28 May 2010
vasi
I owe you two Cokes; it works again!
Thanks! And thanks everyone!
Time to go build a windmill now.
. . . . . Mac
Copeville, Texas
vasi
Posted: 04:51pm 28 May 2010
Hi Mac,
I really did nothing but I'm glad is working again. Some how I'm surprised to see how many problems are in Macintosh garden. Some of the problems are old and not solved.
Thanks for the first coke and the second one goes to GreenD88 and the third one to the author of that blog .
I'm watching your progress with your little windmill.
P.S. As a note, switching to Intel processors was a bad move from Apple part IMHO (and now they must continue to play this game). The new PowerPC 7 processors form IBM are great (hope the owners of apple regret the move).
GreenD88
Posted: 11:46pm 28 May 2010
One last thing you might to check is the EFI is up to date. It's like the bios on PC's. Controls all the start up stuff. You can type in your model number and EFI Update into google and find something I bet.
