Forum Index : Other Stuff : My Kind Of Nuclear Power
| Greenbelt Guru Joined: 11/01/2009 Location: United StatesPosts: 566 |
Self regulated, Naturally shielded, Waste products are safely stored, A closed loop system that discharges no pollution to the enviornment and very likely $Millions Cheaper than a Reactor. This British Web site has a great article who's time has come. 5 Km Down Another thought comes to mind, A well that is drilled anywhere on dry earth to a depth of 20 thousand feet will have a substantial rise in temperature at the bottom of the Hole, Refrigerants could be used to drive Turbines without the need for 300 Deg.C. EDIT: Big mistake-- This is not the Company's Web site.--- WAS (This British Web site is a Company who's time has come.) Roe Time has proven that I am blind to the Obvious, some of the above may be True? |
MacGyver![]() Guru Joined: 12/05/2009 Location: United StatesPosts: 1330 |
Greenbelt It's funny, but I've thought about this several times in the past. Where I live (San Diego) there are hot springs galore just 50 miles north at Murrieta Hot Springs. Could be that's where they got the name, ya think? At any rate, a well only a hundred feet deep or so gets a bottom temperature enough to boil mud, so one would think it would also be enough to make steam and generate electricity, even if it were only good enough for a reciprocating engine. All that would be necessary is to make it larger and it'd be ale to drive a megawatt alternator. Seems to me it should work. I'd like to see someone merely sink a metal coiled tube into a hole and run water through it to make steam for use at the surface. Seems that would be as unobtrusive as it gets, so all the tree huggers and Sierra Club folks don't get their panties all in a wad! . . . . . Mac Nothing difficult is ever easy! Perhaps better stated in the words of Morgan Freeman, "Where there is no struggle, there is no progress!" Copeville, Texas |
HI MAC; Yes there are many places where the hot earth could be used to generate power it must be too easy or it sounds a little to much like Snake Oil to a Banker when you ask for a Loan to develop it.?? Mount ST.Hellens about 50 miles south of Me Has enough Heat to supply Seattle local area for a hundred years or more. Mount Baker about 60 miles North has a chimney that reaches 14,000 Ft. into the sky, It's been smoking for all the 48 years I've Lived in this state. It's only 100 Ft. shorter than California's Mt.Whitney. Some time ago I drove through California;s Mt.Lassen Volcanic national park where little red hot pools of Lava dotted the roadside, Of course Mt. St Hellens is on the Books to become another National Park , Yellowstone Nat'l Park with it's boiling lakes and Geyser's I will take a guess on the size of this Park 30 x 30 miles That's 900 square miles of hot rock. The Government likes the thought of having a brisk uplifting aroma of Sulpher dioxide while viewing our national Heirlooms. The Idea is "NO CHEAP FUEL". Now that My Gripe is over, there are places that use the Geo. They were established before the Gov. Had control of the natural resources. Here is a Link that is very educational, Any persons interested in Geothermal, Solar, Hydro, and wind will find something interesting here. I saw a Link on the referenced site to a world wide Map of Geothermal. Geothermal Map for the United States Time has proven that I am blind to the Obvious, some of the above may be True? |
