Forum Index : Other Stuff : run a f&p motor from the wing gen batter
BIGDOG![]() Newbie Joined: 23/06/2010 Location: Posts: 5 |
hi, is it possible to run a modified f & p motor at a lower voltage (the batteries charged from my f&p wind gen.) for powering an electric scooter or buggy etc. thanks glenn |
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5198 |
Hi BigDog Yeah its possible, but its not easy. You need a special controller, which will either be expensive or very time consuming to build from scratch. It is much much much easier and cheaper to buy a high power scoota motor and controller. You can pick up a 500 watt motor for $90 at http://secure.oatleyelectronics.com//index.php?cPath=53&osCs id=78c9516a506712be955423b51a509ac6 Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
gizmo, with some serious mods is something like this a possibility? http://www.icaro2000.com/Products/Trike/Trike.htm glenn |
Downwind![]() Guru Joined: 09/09/2009 Location: AustraliaPosts: 2333 |
Pigs might fly but i would not like to see a washing machine fly.
To build a bike with a F&P is one thing and you could always walk home when it failed but to use one to fly with would be asking for trouble i would think. Several have tried the F&P for solar cars and gave up as they were not efficent enough, as there is better motors for the job. Pete. Sometimes it just works |
Yeah I agree with Pete. The F&P isn't structurally strong enough to supply that sort of power, the 10kw or more thats needed would tear the plastic hub apart. Trev did some work on fitting a series motor designed for a electric car into a light plane. http://www.thebackshed.com/windmill/forum1/forum_posts.asp?T ID=1128&PN=1 Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
