Local Time 12:39 14 Nov 2026 Privacy Policy
Forum Index : Other Stuff : Replicable CNC
vasi
Posted: 07:49pm 09 Dec 2011
Or, cheap kits made by CNC owners. How reliable can be such a kit?
Anyway, will be nice to have some proposals about design, materials, etc., from CNC experts around here. Not something professional, but workable and reasonable as precision (well, I guess that can come mainly from "sliders").
The construction must avoid complications in assembling the kit.
It must be a maximum of A4 working area (or A3?).
Elvish name: Mablung Miriel
Beyound Arduino Lang
Posted: 11:31pm 09 Dec 2011
I've seen a few designs based on timber frames, and they seam to work OK.
http://www.cncroutersource.com/cnc-router-plans.html
I think timber is a good material, its rigid when layered up and glued, cheap, and also easy to work with. If a timber part breaks its easy to replace or repair.
But it would only be suitable for routing wood, HDPE or other soft materials. Give steel a miss, and even aluminium would be asking too much.
What do you want to do with the CNC Vasi?
vasi
Posted: 12:34am 10 Dec 2011
Hi Glenn,
Exactly what you said, wood, HDPE, soft materials (for "hand made" things, local art, etc.), but also PCB's of medium complexity...
Vasi
