Local Time 21:06 28 Sep 2026 Privacy Policy
Forum Index : Other Stuff : What’s inside a Ram Pump?
Greenbelt
Posted: 05:41pm 08 Apr 2012
Below is 3 links that will show how to build a Ram pump Using only pipe fittings and
a couple of well pump foot valves.
Figuring the flow and head required
Building the Pump
Installing and starting the pump
The fourth Link is a detailed "How to" Rebuild a commercial Ram Pump and a description of the working "Clack Valve" as well as the function of the receiver tank/ pressure vessel.
The author of this project is inspiring with all the projects he has posted on U_Tube, See Wood powered Generator by Engineer775
--------- Cheers Roe
Posted: 11:06pm 08 Apr 2012
Thanks for posting Roe
I've seen these videos before, Engineer775 has some good videos and I subscribed to his page some time ago. I even bought the parts for this pump, ready for a later date.
He explains it well I think.
domwild
Posted: 03:28pm 10 Jun 2012
Thanks for that, Roe.
Winston Churchill
AMACK
Posted: 12:25am 21 Jun 2012
Hi all,
I have a large water ram that was used on the farm quiet some time ago. My uncle over the hill used to use one all the time to move water for the house and stock. When we were kids swimming down the creek we would hold it down and let the flow get up and then let it close and it would make for a good roaster tail of water. When I look back at it might not have been a good idea.
If you want a few photos yell out. I have built a small one out of poly fittings and a check valve from a plan I got some time back that works well. I ran it when I first put it together and blew the top of the pressure cell as the glue was not set. It sent a 100mm PVC end cap about 20Mts in the air off a 40mm poly pipe with 3.5mts of fall over 200mts.
Amack
*Note to self
1. Make it thick
2.Make it heavy.
