Local Time 18:42 28 Sep 2026 Privacy Policy
Forum Index : Other Stuff : Car Onboard Diagnostics
MOBI
Posted: 11:49pm 29 Dec 2012
Hello all,
I'm not sure if this should be in this forum or EVs etc or even at all, but..
I have collected a lot of data on OBD but not had too much time to chew through it all. I'm pretty sure that with dedication I could come up with a reader starting from the ground up.
Has any of TBS members had a play in this area. A bit of mutual discussion would probably give me the incentive to continue.
David M
David M.
yahoo2
Posted: 04:24pm 30 Dec 2012
I do a bit of stuff with industrial and agricultural gear, but that is all a bit secret squirrel, not really appropriate for a public forum.
The best I could do is point you towards the ELM327 V1.4b this little chip is the standard for most of the modern OBDII comms protocols including canbus. It basically converts the data stream to RS-232 (serial). There are interpreter kits and plans around some are good, most are junk.
The quickest route to OBDII data is scantool interfaces and some free software on the laptop. If you are looking to work with older (mid nineties) or proprietary data there is a lot of trial and error involved.
MOBI
Posted: 05:16pm 30 Dec 2012
  yahoo2 said  If you are looking to work with older (mid nineties) or proprietary data there is a lot of trial and error involved.
Hi, Thanks for the links, I'll certainly have a look (if I haven't been there already).
My preference and yes, I know it takes a lot of trial and error, is to build things from "first principles". It takes a lot of research and I get to learn lot more. (it also keeps the ageing brain cells from going too rusty). Its not that I want or need a "scantool", I just want to get one going that I can modify to suit my requirements.
I did the same thing with a 125KHz cattle eartag reader i.e. got it working using "discrete" chips with Picmicro heart and i2c interfaces and then got a TI chip that did all the rfid part. (I still need to "bluetooth" it).
David M.
David M.
muddy0409
Posted: 11:43pm 30 Dec 2012
Are all OBD connectors standard or do different car manufacturers have their own particulay shapes & sizes?
Don't poo poo conspiracy theories.
Remember that everything ever discovered started somewhere as a theory.
MOBI
Posted: 12:36am 31 Dec 2012
  muddy said  Are all OBD connectors standard or do different car manufacturers have their own particulay shapes & sizes?
They used to be different sizes in the very early days but seem now with the OBDII version, to have hit on a common (I think 16 pin) interface. Plugs, sockets and leads to connect from the car to the pc or other are all available on ebay quite cheaply.
The protocol is also pretty standard these days also but there are still at least two formats being used.
My reading of the subject hasn't been too 'in depth' yet as I'm still in data gather mode.
Have you had anything to do with OBD?
David M. Edited by MOBI 2013-01-01
David M.
yahoo2
Posted: 02:51am 31 Dec 2012
I remember my first scan tool, had to manually enter an ID code to poll the ECU for real time data. The data for that ID would come back as HEX which had to be converted to decimal then scaled for what ever unit it was supposed to represent.
I threw it very violently in the bin and stomped out of the workshop.
returned 10 minutes later, fished it out of the bin, saved the cable, belted it with a hammer and threw it back in the bin EVEN MORE VIOLENTLY THAN THE FIRST TIME.
My dad thought it was hilarious.
MOBI
Posted: 03:12am 31 Dec 2012
  yahoo2 said  I remember my first scan tool
Hmmm. That doesn't engender a lot of confidence in one.
Never the less, I'll press on until it gets too hard. Nothing ventured....
  Quote  belted it with a hammer and threw it back in the bin EVEN MORE VIOLENTLY THAN THE FIRST TIME.
I wish I'd been there at the time - I know the feeling.
David M.
David M.
