Forum Index : Other Stuff : Forum Operations
| panky Guru Joined: 02/10/2012 Location: AustraliaPosts: 1134 |
Hi Gizmo, In any particular forum, would it be possible to add an option to the search by drop down list of "All topics I have posted in"? I have trouble keeping track of where I have commented
Congratulations on a truly great and usefull forum. Regards, Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
| yahoo2 Guru Joined: 05/04/2011 Location: AustraliaPosts: 1166 |
Have you tried searching by username? I think that should work.
Mine runs to eight pages!I'm confused, no wait... maybe I'm not... |
Thanks yahoo2, didn't thinks that!
Cheers, Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5198 |
Thanks Yahoo The other function you can use is the Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
