Local Time 15:40 28 Sep 2026 Privacy Policy
Forum Index : Other Stuff : Manual gen transfer switch
domwild
Posted: 09:11pm 05 Oct 2013
Sorry, Dr Google is no help.
Manual transfer switch, max 20Amps, 240VAC, 2 poles in from main, 2 poles in from gen, 2 poles out to load. Google talks of 100 Amps and above, automatic ones, 6 circuits, etc., all the stuff I do not want.
Any brand/model no. + Oz supplier would be appreciated.
Winston Churchill
Downwind
Posted: 01:42am 06 Oct 2013
It dont matter diddly squat if the switch is over rated for the job, just dont under rate the switch.
So a 100 amp switch is more than suitable with a over rating.
Just make sure your transfer switch is a "break before make" switch.
Most switches like this have a Off point in the middle, ON - OFF - ON.
A standard switch use for electric hot water for "Day / Night" control is mormally like this and about what you want.
As the use of such a switch is normally to switch between "J" tariff or "M" tariff for water heating, so they have a Off period in the middle.
Pete.
Sometimes it just works
Posted: 04:05am 06 Oct 2013
I use a switch like this switch in my meter box to select 240V power from stand alone inverter or grid.
You can get these switches made up for any configuration.
I did not buy mine from RS electronics as they are way too expensive there.
Find a local supplier for Kraus & Naimer rotary switches and have one assembled to your requirements.
domwild
Posted: 01:11pm 06 Oct 2013
Thanks Tinker and Downwind. Re 100Amps: Being a pensioner (whinge, whinge!) I look at it that way, if the gen is only 3000W, then 20Amps is cheaper and good enough. The rotary one looks OK and is a panel mount one, perhaps there is such a thing as a DIN-rail mounted one available somewhere.
Winston Churchill
Downwind
Posted: 03:58pm 06 Oct 2013
A 2 minute look on the web would do you well in finding what you want.
For example a 60 sec look found me these.
http://www.rexel.com.au/products/NIGHTOFFDAY-CH-OV-SW_4PS25C O_81055.html
http://www.rexel.com.au/products/AUXOFF-MAINS-CH-OVER_4PS40C AM_81057.html
domwild
Posted: 01:14pm 08 Oct 2013
Thanks Downwind. Probably used the wrong search terms like
Generator changeover switch or
Generator transfer switch
and a short fuse on my part does not help either; sorry! As I need to break before make two poles (active, neutral) I will persist and try to find a cheap two-pole switch, like the day/night switch from before.
Winston Churchill
domwild
Posted: 01:06pm 12 Oct 2013
Found it! Whirlpool/grid gave me the answer by listing the Oz/NZ standard for non-permanent connection of gen with a diagram how to connect the break-before-make switch, etc. and now one can talk to the sparkie with confidence.
Winston Churchill
