Local Time 15:40 28 Sep 2026 Privacy Policy
Forum Index : Other Stuff : Which rewiring option for pedal power?
nzTim
Posted: 11:02am 13 Nov 2013
Im making a pedal power bike to charge a 12v AGM battery through a controller.
Does anybody have any thoughts on the best rewiring option for the smart drive?
2X7C
7X2C
7X2Cdelta
or maybe
7Phase 3X2C
Any suggestions would be most helpful
Many Thanks
Tim
Posted: 01:02pm 13 Nov 2013
How fast do you want to pedal? Direct drive, or will you use a chain and sprocket drive where you can try different ratio's.
Also, which stator do you have, a 60, 80 or 100?
Have you seen the pedal power page http://www.thebackshed.com/Windmill/articles/PedalPower.asp
nzTim
Posted: 01:11pm 15 Nov 2013
  Gizmo said   How fast do you want to pedal? Direct drive, or will you use a chain and sprocket drive where you can try different ratio's.
Hi Glen. I was going to aim for 80rpm but go through bike gears to spin the rotor faster. How fast - im not sure, ill have to experiment a bit Edited by Gizmo 2013-11-17
