Local Time 16:27 28 Sep 2026 Privacy Policy
Forum Index : Other Stuff : rossi welders
phill
Posted: 09:13pm 13 Dec 2013
hi folks. new here and love some of the threads. Been reading bits here and there. i am an electrician who has many projects on the go and felt it time to buy a tig/plasma so bought a rossi 200P but without leads. have bought a plasma and tig torch but need to change the start switch plugs. anyone know the pinouts? hard to get info from sellers cause " i didn't buy from them"....
phill
Posted: 08:18pm 14 Dec 2013
ok, pulled the cover off to replace switch socket with a new, more readily available type. Not hard to replace plugs on torch leads. Both are 7 pin. found 5 pins used. 2 obvious different circuits. one has 2 wires going to a small board with board connected to front panel. other circuit is 3 wires going to front control panel direct. suspect the 2 wires are on switch for tig/plasma guns and 3 wire is for foot switch tig control.
