Forum Index : Other Stuff : Anyone built a EDM?
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5198 |
Thinking of adding a EDM head to my CNC router. EDM, or Electric Discharge Machining, is a way to machine metal using a electric current. There's a few home made EDM guides on the internet, but I thought I would ask the forum if anyone had experience in building their own EDM. My CNC is fine for machining wood or plastic, but not rigid enough for any metal work, so a EDM attachment make sense. It would be a slow process, but could be used for some intricate work. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Downwind![]() Guru Joined: 09/09/2009 Location: AustraliaPosts: 2333 |
No i have not, but i did take a interest in the idea some years back when i came across it by accident. It all seemed simple enough, but im sure there is.... Home builder Beware. learning curve to make it all work correctly if one actually can. Perhaps a little easier if someone has actually run a EDM and know the requirements from experience. Still im interested too in this project. Pete. Sometimes it just works |
MacGyver![]() Guru Joined: 12/05/2009 Location: United StatesPosts: 1330 |
Glen You do realize an EDM runs UNDER oil, right? The piece of work is submerged in clear oil and as the discharge does its thing, the oil cools things as well as conducts the small chunk removed, away from the work. Not sure how you would make this happen, but I'd be interested in following your progress here. Best wishes, . . . . . Mac Nothing difficult is ever easy! Perhaps better stated in the words of Morgan Freeman, "Where there is no struggle, there is no progress!" Copeville, Texas |
