Local Time 14:50 28 Sep 2026 Privacy Policy
Forum Index : Other Stuff : Makers are The New Industrial Revolution
vasi
Posted: 04:13am 18 Mar 2014
An ATMEL blog worth reading:
http://atmelcorporation.wordpress.com/2014/03/18/why-makers- are-the-new-industrial-revolution%E2%80%A8%E2%80%A8/
Elvish name: Mablung Miriel
Beyound Arduino Lang
M Del
Posted: 10:57pm 18 Mar 2014
A 3D printer like these would be handy to make some of the bits that are designed to break after a set number of pushes or uses.
I have not seen one yet that will print metal parts however.
But I guess you could use the plastic printed part to make a mould and then use die cast aluminium or your preferred metal into the mould for your finished product.
A mini foundry, not an item for the faint hearted and not something to be taken lightly either.
On a small scale how much harder would it be than making sinkers and casting numbers/letters?
Mark
