Local Time 10:26 14 Nov 2026 Privacy Policy
Forum Index : Other Stuff : Home power
Ganderwings
Posted: 09:15am 08 Nov 2007
Greetings Folks,
Here is a new breeze from BC Canada.
Perhaps some day when you step out side and look up in the sky at your prop and it isn’t turning, you can just walk over to your shed and pull start your window motor energizer, WHICH YOU JUST BUILT, loading those caps or fooling the battery into free work and way it goes producing power without any wind or any other fuel.
No, No I am not trying to pull your leg. I AM DEAD SERIOUS and know well how touchy this statement is.
Fight-4-Truth is my number one aim and helping my neighbor is the other, which we all are supposed to be doing!!
Have a look through my web pages and you will notice that I try to back my statements the best I know how. You can’t loose it is all for free!! Perhaps start with the “schematics illustrated” it is the page I get most of the hits:
http://www.fight-4-truth.com/Schematics.html
If only the lack of experience in electricity is holding you from jumping at it with "all four", then just read through my work shop and start from scratch, by the time you have read all my Bedini pages and have practiced some of the switching procedures, you'll be ready to build your own electrical energy generator, I mean creating your own power. :)
ERWIN
ERWIN
Feral
Posted: 11:15am 08 Nov 2007
ERWIN
They don't like that sort of talk on this site.
Over-unity or something for nothing is just not acceptable of even possible to some of the people who take part in discussions here. If your have an interest in these impossible theories you should check this site, http://www.lutec.com.au/ as these individuals are in Cairns and I have seen most of their machines and the latest prototype does do all that is claimed, 200W in and 1500W out.
AllanS
Posted: 10:09pm 08 Nov 2007
Engineers Reporting Negative Results: Rosenthal and Cole ~ Ian Bryce
Report by Sterling D. Allan (March 8, 2003)
Engineers, Walt Rosenthal and Parke Cole were invited to measure the Lutec1000. Their measurements showed results showed 28% efficiency. The exchange was amendable, despite the negative test results. Rosenthal stated, "I walked them through the calculations carefully so they would understand, but they didn't want to believe the results." Test entailed a dynamometer measuring output the motor, powering with power supply from wall producing DC volts, optical shaft encoder on end of shaft to measure rpm. Results showed 50 Watts power going in and 14 Watts equivalent of mechanical power coming out.
After receiving the above synopsis, Walt Rosenthal added the following:
Report by Walt Rosenthal (March 8, 2003) ~
The inventors would start with fully charged batteries for the demonstration. They assumed that the battery terminal voltage would decrease linearly as the battery was used. So, after using the battery for, say, 30 minutes, they would again measure the battery terminal voltage, and subtract this value from the start voltage, then multiply that difference voltage times the known amp-hour capacity of the battery bank, to come up with their assumption of the total energy consumed from the battery bank. Unfortunately, battery terminal voltage is almost flat for perhaps 90 percent of the battery capacity, before it drops off rather steeply for the last 10 percent of it's capacity. Parke Cole and I tried to explain this to the inventors. I am not sure we succeeded. We were about the 15th group of people to show up on their door step after they went public. We were the first people to bring our own test equipment. The inventors said that the first people to show up were the Russian Mafia. Our bottom line was 50 watts of DC power input, which resulted in 14 watts of rotary mechanical power output. I hope the inventors have improved their device from where we tested it so that it now matches their statements of it's performance.
Highlander
Posted: 07:20am 09 Nov 2007
Hi Ganderwings, I don't mean to be rude, but could you do the world a favour and commit suicide?
Central Victorian highlands
matt down south
Posted: 09:56am 09 Nov 2007
some mothers do have them!!!!frank the wank!!!!!
matt
sPuDd
Posted: 01:45pm 09 Nov 2007
Its amazing that at this technological point in history,
with the internet, and library's, and education for all,
that 95% of people are just F$#@ing stuuuupid...
I'm sure this subject was covered in year 8 or 9 science.
Did these people skip that class?
Were they out the back smokin' weed ??
I'm with Highlander.
Edited by sPuDd 2007-11-10
It should work ...in theory
matt down south
Posted: 02:12am 10 Nov 2007
whats this "lady's thing" selling?
matt
Jon Bennett
Posted: 09:04am 10 Nov 2007
Free energy weirdos are everywhere, some of the reactions do seem a little over the top though.
regards
jon
Ganderwings
Posted: 07:17am 11 Nov 2007
Hello Folks
Ah, there is one in the crowd who dares to speak up against this senseless people walking around with tunnel vision and wool pulled over their eyes by the opponent.
Thanks Jon.
What got me interested in this forum was the website author’s comment on the first page: “I'm not here to make money, the satisfaction I get from sharing idea's and helping others making clean free power of their own is payment enough.” Very good!
1. Feral,
Take another look into my text! Do you see the wording:” Over-unity or something for nothing” anywhere in it? Who are ”they” that don't like that sort of talk on this site. Are you talking about your buddies? Speak for yourself mister. Your obvious eagerness taking my posting out of context is a way of lying and reeks of deception. Why would you bring Lutec A.P.L. in my discussion; Does this line up with my text? The first thing you see if you look at their website is a 100’000.00 $ figure jumping at you. If you say yes it lines up with my text, to that, then I don’t have to call you a liar, then you are one. I am not talking about an impossible theory like you are. If you would have looked at my website you would have noticed that all content is for free and frankly, quite factual. I never talked about getting energy for free I was talking about free education, quote: “Have a look through my web pages and you will notice that I try to back my statements the best I know how. You can’t loose, it is all for free”, has nothing to do with free energy.
2. AllanS,
If you would have read my Energy page you would have read these lines: I do not belief in the term of free energy since no gadget is falling in your lap for free, you'll always have to sweat and reach into your pocket, be it by building it your self with the needed shop equipment or farming it out, unless you try to buy it for big bucks and get taken*$%^. With other words building a self runner is not much different as building a wind or water turbine except perhaps more rewarding. The upkeep will still have to be there, if you built it yourself that is, otherwise you won’t be capable.
Engineers have been turning down for years any inventor who’s invention pointed against their brainwashed theories which they where taught in the universities since Tesla and most likely long before him too. So get lost with any comment made by any engineer.
What has Lutec A.P.L. in common with me? There are many individuals out there praying on society hoping to hook a fool with the term of “free energy”.
There are also many people hired by the financial establishment to be leaders in forums to shut down, discourage, meddle in, or confuse the participants involved with any individuals that promote home power! Sounds like you are one of them!
3. Highlander,
People like you, matt down south and SPuDd are dishonoring this website owner and forum provider by your behavior. Surely you must be individuals on another agenda who obviously are hired to discourage home power especially self runners. You couldn’t possibly be that crude and undisciplined otherwise, or could you?
Any normal human being would accept any gift freely, at least would not be kicking the giver like you did. You are the type of characters who would bite a giving hand.
If you would at least stand by the truth but you can’t even do that. Your own troubled vision won’t allow it to yourselves as your expressions clearly state of your negative characters of dishonor: “Hi Ganderwings, I don't mean to be rude, but could you do the world a favor and commit suicide?”
Any negative rude remark is meant to be that and to say the opposite like: “I don't mean to be rude “, is a straight out lie and deception!!!!
Besides to your suggested commitment of suicide I doubt you having the knowledge in your loosing ignorance of the very detrimental afterlife effect any suicidal soul would have to suffer. Mark my words that you will remember me in the time of trials when God will strike you with the rest of this earth very shortly (see my website), if you make it through it, that is!
4. As for you SPuDd shooting off your undisciplined mouth: “Its amazing that at this technological point in history, with the internet, and library's, and education for all, that 95% of people are just F$#@ing stuuuupid...” perhaps you should look in the mirror. You obviously are to ignorant to know that Tesla created electrical energy to run appliances which motors required no wire connections 26 mile away from the sending unit already in the 1890’s, nor would you be aware that Tesla and Perrigo both and others drove cars running on Radiant Aether Energy in the 1920’s already. You few souls obviously are proving your ignorance having blindly followed the banker’s controlled school teachings all your lives with the obvious brainwashed results. For example not accepting self running equipment is fitting your agenda and you would still deny it in your arrogance even if it bite you in the behind.
John Bediny proved by video running his window motor on its own power. I could show you the link, but I think you do not deserve the favor.
Edwin Gray Rory Johnson, Meyer and many more where killed in the process of trying to help making this earth a better place to stay. You give me the impression of working under the same command of eradicating all who are working for the good of society, which places you under the same agenda of the elite killers, shame on you!!
I think you fellows had this one coming and call therefore this the end of my discussion with folks like your kind.
: Erwin-Badertscher
ERWIN
Highlander
Posted: 07:41am 11 Nov 2007
Ohhhhhhhh Booo Hooooo.
Do you want me to send you some tissues so you can have a little fu*%@ing cry?
Bryan1
Posted: 07:58am 11 Nov 2007
I went and checked out this wankers website and got an eyefull of bible bashing crap.
PLACE YOUR VOTE NOW
LET'S BAN THIS WANKER AS A SPAMMER
Posted: 08:50am 11 Nov 2007
Oh dear, I missed this thread. Just stumbled across it now.
Nothing to say really. Well, maybe just this.
Ganderwings, on your web site you should have kept the religion away from the window motor energizer thingy. That way at least some people may take your claims seriously and look further into your idea's.
Thats all, everyone knows what I think about these sort of things. If I cant see it, or it doesn't obey the laws of physics, then I dont believe it will work. But thats just me and everyone else is free to have their own opinion.
sPuDd
Posted: 03:02pm 11 Nov 2007
Ganderwings,
You are an insult to the human race.
You stole your idea from Gravity Kitty.
Shame on you.
vasi
Posted: 03:17pm 11 Nov 2007
Ganderwings, go to a doctor(electroshock therapy, we can give schematics if is need) and take Bertha Dudde with you. And ask a nurse about a Bible. A real one. And don't use it for your tricks. Find stupid people in other places.
By the way, your eyes tell me something: your grin is false!Edited by vasi 2007-11-13
Elvish name: Mablung Miriel
Beyound Arduino Lang
vasi
Posted: 03:43pm 11 Nov 2007
  Ganderwings said  I AM DEAD! SERIOUS!
I belive you!
Jon Bennett
Posted: 07:47pm 11 Nov 2007
Wasn't actualy agreeing with the concept of free energy at all!
regards
jon
AllanS
Posted: 09:41pm 11 Nov 2007
Lots of people spend their time and money chasing dreams. Trading the futures against the pros. Playing the pokies. Inventing free energy devices.
I think this is just the way our brain works. We're guided more by intuition than by reason, and if you feel your system can beat the casino (or whatever), you just go for it until you hit the wall.
In a word, there's no call to crucify Ganderwings, no more than you'd crucify the punters at the local TAB. Good luck to him, I say, because I reckon he'll need it. Edited by AllanS 2007-11-13
dwyer
Posted: 09:42am 12 Nov 2007
Hi Ganderwings
Look mate l have spend my wasting time looking your concept of free energy other night but now all chasing dream that belong to pack of Bible basher who pray for the evil that they all live on fear? stupid
OOnce you are dead that is end of it there is nothing up in the sky as rocket people didnt find heaven ? just space
regard ian
vasi
Posted: 09:52am 12 Nov 2007
Hi dwyer,
Last night, a rocket flea jumped from my dog's ear. On the ground, looked around and said:
- Hey, no Australia around here!!! This "country" don't exist!
Highlander
Posted: 10:57am 12 Nov 2007
Let's all remember why we're here.
To advance renewable energy and perhaps, freedom from the grid.
