Local Time 12:46 14 Nov 2026 Privacy Policy
Forum Index : Other Stuff : Smartdrive uk
Dirtydirk
Posted: 10:55am 16 Feb 2016
New member
Having trouble finding smartdrives in the UK , found 2 both where aluminium windings shall I go to the trouble of rewinding the coils in copper or use as stock? If I rewind the coils what gauge wire? I'm hooking it up to a Seahawks wawt
Thanks all dirkEdited by Dirtydirk 2016-02-17
rustyrod
Posted: 01:09pm 18 Feb 2016
Have you read THIS ?
Can you reconfigure your aluminium windings?
Re connecting aluminium electrically I think may be a challenge,
However something like EXAMPLE may be helpful and a steady hand.
I would try one with the original windings, then when you have it working decide either to go again or a rewire in copper.
Always Thinking
Dirtydirk
Posted: 10:42am 19 Feb 2016
Thanks that was my plan . I did have Hugh piggotts book on turbine construction with a good section on winding coils but I've lost it , thicker or thinner copper wire for slow speeds just can't remember the stock stator has 1mm wire but that's aluminium, so if enyone has eny thaughts please jump in
