Local Time 10:26 14 Nov 2026 Privacy Policy
Forum Index : Other Stuff : Another use of a two old microwave ovens
vasi
Posted: 05:31am 28 Dec 2007
Hi Glenn,
I found here how to use two microwave ovens as welder. You need too many old microwave ovens for an axial alternator but for a welder, only two are enough (thinking to axial alternator from Ed - windstuffnow, reusing magnets from magnetron).
Elvish name: Mablung Miriel
Beyound Arduino Lang
Posted: 01:56pm 28 Dec 2007
  vasi said   Hi Glenn,
It looks interesting Vasi but it also is a lot of work to end up with a rather ordinary welder. 70 amps max is only going to weld thin stuff (<2mm).
A far simpler welder can be had by connecting two or three 12V car batteries in series, then connecting the negative end to the electrode and the positive end to the work. A length of thick fencing wire for the series connection could act as a current limit.
This method is often used bt 4WD enthusiasts when they break something out in the bush. I got the URL somewhere for that idea, if you are interested.
vasi
Posted: 08:56pm 28 Dec 2007
Yes, why not?
Posted: 01:21pm 29 Dec 2007
  vasi said   Yes, why not?
Here it is:
http://www.lcool.org/technical/80_series/bat_weld/battery_we lding.html
vasi
Posted: 01:56am 30 Dec 2007
Thank you Klaus, is very good to know this stuff. You fill a little more ... secure.
A little problem with address, resolved.Edited by vasi 2007-12-31
dwyer
Posted: 06:01am 30 Dec 2007
Hi Vasi
Welding on outback in Australa has been done many year back far as 1970 and other intesting story is how to charge flat car batteries when no electric power around is grab some wood, dry grass and light a fire when fire settle down .lot of heat less flames and put the batteries near fire place untill batteries get hot and remove and place into motor veichle and fire the engine and way you go. The ideas come from aboriginal fellers
dwyer the bushman
vasi
Posted: 05:14pm 30 Dec 2007
Yap, another method to keep in mind, thank you dwyer!
wind-pirate
Posted: 01:05am 25 Jan 2008
Try this link http://www.geocities.com/aaawelder/This ia a 70 amp welder made from two old microwaves.
Ron
THE Pirate.
stealing wind & solar energy is fun
