Local Time 09:26 28 Sep 2026 Privacy Policy
Forum Index : Other Stuff : monster neo’s
govertical
Posted: 11:22pm 02 Aug 2017
hi, I purchased two 3 by 2 inch neo magnets. I am planning to fabricate a strong solenoid motor.
https://youtu.be/3nmaBrnycJY
just because your a GURU or forum administer does not mean your always correct :)
govertical
Posted: 07:48am 03 Aug 2017
https://youtu.be/9bzQyEBcQrU
Hi, I completed the solenoid, starting to fabricate crank and flywheel assembly.
Posted: 12:16pm 03 Aug 2017
As I've said in the past, I dont want this sort of contraption on this forum, unless you actually get it working first. I do wish you would take advise offered and go and talk to a science professor or teacher about this, so you can move on and use your brilliant prototyping skills on ideas that will actually work.
You can not generate endless energy from magnets, gravity or flywheels. You must put energy in to get energy out, and you will always get less out than you put in. Its that simple.
