Local Time 16:22 27 Oct 2026 Privacy Policy
Forum Index : Site News : Re problem with Murphy's friend
wiseguy
Posted: 08:10am 12 Aug 2023
Hi when I try to PM "Murphy's friend" nothing happens after I search and then select Murphy's friend, the select window just stays open, if I select the entry name above or below Murphy's friend it installs their names in the send to member just fine.
When I try to search posts by "Murphy's friend" nothing happens after I search and then select Murphy's friend, the select window just stays open, if I select the entry name above or below Murphy's friend it installs their names in the author window just fine.
This has been the case for ages with the PMs but today trying to search for posts I decided to ask you for help as i cant search for what I am after.
Thanks in anticipation... Mike
Cheers Mike
Posted: 08:21am 12 Aug 2023
As a work-around, in your browser search-bar type:
site:thebackshed.com "Murphy's friend"
Add more search words to narrow down the number of results.
Won't fix the PM issue though.
Murphy's friend
Posted: 01:55pm 12 Aug 2023
I just tried Phil99's suggestion, it works!
strangely, I can search all of my posts, clicking from the member list
wiseguy
Posted: 12:34am 13 Aug 2023
Strange indeed, thanks for the suggestion Phil but as there were now 2 weird things going on I thought it was time to report the issue. I think I have been singled out here lol
Cheers Mike
Posted: 11:10pm 13 Aug 2023
I'll make Gizmo aware of this thread.
Maybe he can look into it.
Posted: 11:18pm 13 Aug 2023
Thanks for the heads up G
I can bet its that single quote ' causing the problem.
I'll look into it later this week when time allows.
