Forum Index : Site News : Test Post
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5203 |
Please ignore Edited 2025-08-11 15:21 by Gizmo The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
OKJ, just testing, if you edit a message just after you have saved it, you can now change the forum area and subject. I see a few members posted new threads in the wrong area, and there was no way to correct this. So now, if you edit ( before anyone replies ), you can change the forum area and subject. The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3453 |
Thanks, that will be useful! If we post from Active Topics it winds up in Windmills as that is first on the list of forums. Edit I see "Post to Forum*" and "Subject*" are the new fields. Edited 2025-08-11 15:41 by phil99 |
Yeah dont know why I didn't think of that, it should default to whatever forum you're in. I'll add that to the list. The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Oops! When I tried moving a new post from a page on Microcontrollers to this thread in Site News the entire thread moved! So now there are two Test Post threads. Moved it back to Microcontrollers and PC projects. Edited 2025-08-15 11:27 by phil99 |
Hi Gizmo, Maybe another item for the 'to do' list. In the "Strangeness" thread @Disco4now has mentioned TBS links in old threads using http://... get redirected to JAQ Software. Is it practical to redirect them to https://... ? If not we can change the links when we use them. Edit I think I have restored the "Strangeness" thread but it is getting confusing.!! Edit 2 Strangeness thread Edit 3 Apologies, I should have said:- If we start a new thread from Active Topics it winds up in Windmills as that is first on the list of forums. Edited 2025-08-15 18:11 by phil99 |
![]() Test upload. Have been some PHP security updates done and wanted to see if uploading was still working. The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Image upload test ![]() The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
