Local Time 07:48 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : The Amiga 500 emulator for the Colour Maximite 2 G2
Posted: 03:29pm 10 Nov 2026
This has pushed the CMM2 to the limit but I think the results are spectacular
An Amiga 500 on the Colour Maximite 2
A new program in the 7.00.00RC5 programs zip, for the Generation 2. It needs firmware 7.00.00RC5.
https://github.com/UKTailwind/CMM2V1.5/releases/tag/v7.00.00RC5
What it is
It is pico-amiga, drewpo28's Amiga emulator for the RP2350, with Karl Stenerud's Musashi 68000, and a new front end for the CMM2.
• An Amiga 500 with 1MB of memory (512K of chip RAM and 512K of slow RAM) and its original chipset, on Kickstart 1.3.
• A PAL Amiga at its own 50 frames a second, shown in 720 x 576 at 50Hz (576p) with each Amiga line drawn twice, with Paula's stereo sound. The heaviest demos tried, Mental Hangover (Scoopex) and Arte (Sanity), keep up all through with the sound on.
• -ntsc gives an NTSC Amiga at 60 frames a second in 640 x 480, and -pal60 the PAL Amiga at 60Hz for a monitor that will not take 50Hz (it then runs 20% fast).
• It runs on the Generation 2 only.
You need a Kickstart and disks
No Amiga software comes with it. Kickstart and Workbench are still copyright, so they cannot be given away with the emulator. If you have an Amiga, use its Kickstart and disks. If you do not, we recommend Cloanto's Amiga Forever, https://www.amigaforever.com: it is the legal way to get them today, and costs little. Its Value Edition, the least costly, has everything the emulator needs: Kickstart 1.3, the Workbench 1.3 disk, and over 50 games and demos.
Copying the files from Amiga Forever
Install Amiga Forever on a Windows PC. Its files are then in C:\Users\Public\Documents\Amiga Files. Copy these to the folder A:/amiga on the SD card:
• Shared\rom\amiga-os-130.rom, Kickstart 1.3. Keep its name exactly: the emulator looks for amiga-os-130.rom by itself.
• Shared\adf\amiga-os-134-workbench.adf, the Workbench 1.3 disk. Any name will do, such as workbench.adf.
The games and demos are in Titles\Games and Titles\Demoscene, an .rp9 file each. An .rp9 file is a zip file with the title's disk images in it: copy it somewhere, rename it to end .zip (or open it with 7-Zip), and take out its .adf files. A game on several disks has one for each, numbered. Put them in A:/amiga, or in folders inside it such as A:/amiga/games and A:/amiga/demos: the disk menu goes into folders.
Only titles made for the Amiga 500 run. One whose zip has a .hdf file (a hard disk) rather than .adf files, or which is marked for the Amiga 1200 or 4000, will not, and nor will amiga-os-310-a1200.rom.
Getting started
Copy the amiga folder of CMM2_Programs_7.00.00RC5.zip to A:/amiga with the files above, then:
CHDIR "A:/amiga"
RUN "amiga.app"
It starts with its disk menu. Choose a disk with the arrow keys and Enter, then Boot it. To start a disk straight away, name it: RUN "amiga.app", games/zoom.adf
The disk menu
F11 brings up the disk menu at any time, in the middle of a game too, and the Amiga waits while it is up.
• Up, Down, Page Up, Page Down, Home and End move through the list, and a letter jumps to the next name that starts with it.
• Enter opens a folder or chooses a disk, and Backspace or Left goes up a folder.
• Esc or F11 goes back to the Amiga as it was.
A disk chosen can be booted (the Amiga restarted with it in DF0: use this to change game), put in DF0 as a disk change, for a game that asks for its next disk, or put in DF1, the second drive. The menu also makes a new blank disk in the folder shown. A gamepad works the menu too.
Saving your work
What the Amiga writes to a disk goes into its .adf file on the card as it is written, as onto a real floppy disk, so saved games, high scores and your own programs last.
• For your own work: Workbench in DF0, then F11, [ A new blank disk, made here ], and put it in DF1. It is named Work1 on the Amiga: save to Work1:
• A read-only .adf file is a write-protected disk, and is never changed. RUN "amiga.app", game.adf -wp protects every disk.
• The RAM DISK is lost at a reset, as on a real Amiga.
• There is no BASIC in the Amiga's ROM: AmigaBASIC came on the Workbench 1.3 Extras disk, which is not in Amiga Forever's Value Edition. If you have that disk, put it in DF1 with Workbench in DF0, and AmigaBASIC runs from it, its demos too. If you do not, a copy is on the Internet Archive, https://archive.org/details/amiga_extras1.3_basic1.2: download and use it at your own risk.
The keys
F11            the disk menu
F12            back to MMBasic (Ctrl+Alt+End too)
Ctrl+Alt+Del   reset the Amiga (Ctrl and both Amiga keys too)
Windows keys   the left and right Amiga keys
Insert         HELP
The keys are taken by their place, as on an Amiga keyboard. Workbench 1.3 starts with the American layout: on a British keyboard, type SetMap gb in a Shell.
The mouse and joysticks
• A USB mouse is the Amiga's mouse, in port 1. It is read every 2ms, so fast movements are not lost.
• The first USB gamepad is the joystick in port 2, where nearly all games look, and a second one the joystick in port 1. The d-pad or the left stick steers, and any face button fires.
What has been tried
On a Generation 2 with 7.00.00RC5:
• Demos: Mental Hangover and Arte at 50 frames a second all through with the sound on, and 242 (Virtual Dreams and Fairlight). D.O.S. (Andromeda) falls just short in a few places.
• Workbench 1.3, with the mouse and the keyboard, and AmigaBASIC from an Extras disk in DF1, running its Demo program.
• Games from Amiga Forever, each for a minute: Arkanoid, Aunt Arctic Adventure, Blasteroids, Datastorm, Exile, Gotcha, Lethal Xcess, Obsession Pinball, Pac-Mania, Rage, Statix, Toobin and Zoom! load and run at 50 frames a second.
Known problems
• Interlaced screens show every other line.
• Collisions between sprites and the playfield are not reported, which a few games use.
• Tie Break shows only a black screen, and X-Balls and Logic load slowly through AmigaDOS.
Licences
pico-amiga is under the GNU GPL version 3, and Musashi under the MIT licence. Its source is github.com/drewpo28/pico-amiga, with the CMM2's front end and changes in apps/amiga of the firmware's repository. No Kickstart, Workbench or other Amiga software comes with it.
homa
Posted: 08:30pm 10 Nov 2026
Peter, I'm blown away.
I feel like it's Christmas. Most of the demos are working. “Desire - Inside the Machine (2024)” seems to be too challenging.
Now it's time to move on to the games...
Thanks!
Matthias
Until I find a full-speed keyboard... for now, the hub is working, with the Xbox controller too.
Super Cars I (my absolute favorite) throws a "Guru Meditation" error
Super Cars II, on the other hand, runs perfectly!
Edited 2026-11-11 07:32 by homa
Posted: 10:44pm 10 Nov 2026
  Quote  Super Cars I (my absolute favorite) throws a "Guru Meditation" error
If you post I'll have a look. The later titles may be outside the scope and need updated roms or kickstarter
bfwolf
Posted: 02:08pm 11 Nov 2026
For those frustrated with AmigaBasic (by Microsoft) — which is terribly slow and buggy (because Microsoft had no interest in further developing it, nor did they bother to hand over the source code to Commodore — surprise, surprise)  — there is an alternative:
ABasiC, which was included with the early Amiga 1000 models (running Kickstart 1.0) and developed by Metacomco (a division of Tenchstar Ltd.). Metacomco was also responsible for the TRIPOS operating system, which served as the foundation for AmigaDOS.
You can still find the relevant disk, for example, here:
http://www.rbenda.de/commodore/software.html
It's the file linked by "A1000 Basic V1.0 (318KB)", saved with the DMS disk-masher.
http://www.rbenda.de/commodore/_basic-1_0.dms
I have also attached it here for you as a zipped (convertet from the DMS) ADF file:
ABasiC.adf.zip
ABasiC is a more "traditional" BASIC, utilizing line numbers. In general, it is quite fast and stable. However, the original version encounters issues with newer Kickstart versions (from 2.x onwards, I believe) and with Amiga systems equipped with large amounts of RAM. Furthermore, the original version is hardcoded for NTSC screen modes (200 vertical lines), though it will still function on PAL-based Amiga systems.
Consequently, a patch was released to address these problems:
https://aminet.net/package/dev/basic/ABasiC_patch
And there you also find examples:
https://aminet.net/package/dev/basic/ABasiC_progs
Some time ago, I took the trouble to create several patched binaries (fixing bugs, adding PAL support, and enabling right-mouse-button functionality) — you can find them in this ZIP file:
ABasiC-versions.zip
Oh, and the manual is available as well — a high-quality scan can be found here:
http://www.trailingedge.com/amiga/Amiga%2520ABasiC%2520Reference%2520Manual.pdf
BTW: At one point—for a few days around the turn of 2015/2016 — the source code for AmigaOS 3.1 were leaked online (which I, of course, did *not* download! *ahem*), and that leak also included the source code for ABasiC...
Regards, bfwolf.
twofingers
Posted: 02:18pm 11 Nov 2026
  Quote  Oh, and the manual is available as well — a high-quality scan can be found here:
Or here:
https://www.trailingedge.com/amiga/Amiga%20ABasiC%20Reference%20Manual.pdf
works for me
Thanks!
Michael
Edited 2026-11-12 00:19 by twofingers
homa
Posted: 03:49pm 11 Nov 2026
Posted: 04:18pm 11 Nov 2026
I meant post the game file What roms are you using? exact versions?
Edited 2026-11-12 02:21 by matherp
homa
Posted: 05:06pm 11 Nov 2026
You received an email ;-)
Edited 2026-11-12 03:07 by homa
Posted: 06:37pm 11 Nov 2026
Fixed, re-download from github for the fixed version
homa
Posted: 09:41pm 11 Nov 2026
darthvader
Posted: 11:44am 12 Nov 2026
Are the 8mb sdram that made it not compatible with the G1 ?
Regards.
Posted: 11:48am 12 Nov 2026
yes, and it would need overclocking to 480MHz
Posted: 02:39pm 12 Nov 2026
Matthias, please download the app again from github and try Desire again - let me know if it is improved - thanks
https://youtu.be/Y2nFIrSHoBA
Edited 2026-11-13 01:01 by matherp
homa
Posted: 07:52pm 12 Nov 2026
Peter,
things are going much better, but you can tell that the CMM2 is reaching its performance limits. Still, it’s getting the job done despite some minor fluctuations!
Your engineering skills are impressive. Thank you.
Matthias
Posted: 08:05pm 12 Nov 2026
The amiga emulator is the only app that gets to the limits. The issue is the implementation in S/W of the Amiga's H/W 4-plane blitter and all its combinational logic
homa
Posted: 09:16pm 12 Nov 2026
I had assumed that the special "hardware-related" features, like the blitter, would be a problem, since so much on the Amiga depends on its three custom chips: Agnus, Denise and Paula. So it’s all the more amazing how well it works. The graphics and sound are truly impressive.
Now the only thing missing is really the Atari ST from that era of the C64 and Amiga 500. :-)) You love a challenge, don’t you?
Matthias
