Forum Index : Microcontroller and PC projects : Filename length on CMM2 SD filesystem....
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10109 |
Hi all. What is the maximum filename length on the CMM2G2 with the latest FW from Peter? How long can the filenames be on the SD card? Smoke makes things work. When the smoke gets out, it stops! |
| panky Guru Joined: 02/10/2012 Location: AustraliaPosts: 1145 |
RC4 page 94, 127 for files and directories. For FAT32 file names 255 so the CMM2 limit of 127 applies. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
Ta. ![]() Smoke makes things work. When the smoke gets out, it stops! |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9329 |
For anything sensible, 8.3 in caps only. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
It's my old Atari .ATR disk images. The filenames contain all the games in the image, so the filenames can be pretty long! MOST of them load fine on the CMM2 and the atari800.app, but some images don't. I just get an error: "Cannot load disk image file." There is no reason WHY, but I suspect it is filename length, pretty much all the other ones DO load and run just fine. Might just need to rename some files I think. ![]() Smoke makes things work. When the smoke gets out, it stops! |
