Local Time 07:48 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite problem to read data from a Generic USB Gamepad
Arne
Posted: 07:48am 12 Nov 2026
Hello,
to read data from a generic gamepad I did following steps:
- connect gamepad to USB
- Feedback: Generic Gamepad Connected on channel 3
- Run following program:
DO
PRINT DEVICE(GAMEPAD 3, “B“)
PAUSE 100
LOOP
When I press (and hold) a button on my gamepad the result is always 0.
If first GAMEPAD MONITOR ON was set on every button I press a protocol is printed.
I also tried with interrupt. When I press a button on the gamepad it is recognized but printed also zero only.
Where is my failure in reading gamepad data?
Arne
Posted: 09:39am 12 Nov 2026
This appears to be a bug and I'm trying to find when it was introduced. If you boot the Picomite withe the gamepad already connected you should find it works
mozzie
Posted: 10:21am 12 Nov 2026
G'day,
Just purchased a couple of the "Generic" gamepads for input devices on CNC machine. These are not a recognized generic device.
Now I have these setup with GamePad Configure in MM.Startup they work if plugged in on startup as well as subsequent reconnect.
So it may just be the inbuilt support mapping that has failed.
Hope this helps.
Sub mm.startup
Gamepad configure 2064,1,6,1,6,5,255,255,6,4,6,0,4,192,3,192,4,64,3,64,255,255,5,4,5,5,5,7,5,6,255,255,255,255
End Sub
'prog to test joystick
Option default integer
CLS
Print Chr$(27)+"[2J"+Chr$(27)+"[H"; ' clear console
If MM.Info(usb 3) <> 130 Then
 Print @(80,48)"Unplug / Replug Gamepad"
 Do :Pause 100:Loop Until MM.Info(usb 3) = 130
EndIf
Print @(80,48)"Gamepad Button States  "
gameint ' initialise readout
Gamepad interrupt enable 3,gameint
Do :Pause 100:Loop While Inkey$=""
Gamepad interrupt disable 3
End
Sub gameint
 Print @(80,60)BIN$(DEVICE(gamepad 3,b),16);
End Sub
Regards, Lyle.
Posted: 10:28am 12 Nov 2026
There is a USB host bug that I'm working on
