Local Time 23:00 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite - Displaybox and line breaks
rhiemann
Posted: 08:36am 24 Nov 2017
I am using micromite plus version 5.0405 with displayboxes.
The behaviour seems to be not correct if I am using line breaks (~)
A simple program with 6 display boxes, with 3 different font sizes. 3 with line breaks (~) and 3 without.
Multiple rows should work.
Image upload did not work so I have to write the content of the message boxes here:
behaviour incorrect, last characters are not printed, size of displaybox is big enough (display 800x480)
"ABCDEFGHIJKLMNOPQRSTUVWXYZ~ABCDEFGHIJKLMNOPQRSTUVWXYZ~ABCDEFGHIJKLMNOPQRSTUVWXYZ"
font 1
ABC
font 2
ABCDEFGHIJK
font 3
A
same text but without ~ for new lines
behaviour correct, stops when display edge is reached
font 1
ABCDEFGHIJKLMNOPQRSTUVWXYZABCDEFGHIJKLMNOPQRSTUVWXYZABCDE
font 2
font 3
The page break works but last characters are not printed. It is always limited to the amount of characters allowed for one row (minus amount of ~ characters)
String limit of 255 should not be the reason.
Any ideas?
Rico
Sample program:
Const Text1 = 21
Const Text2 = 22
Const Text3 = 23
Const Text4 = 24
Const Text5 = 25
Const Text6 = 26
FONT 1: GUI DISPLAYBOX Text1, 10, 100, 460, 100, RGB(black), RGB(255,255,255)
FONT 2: GUI DISPLAYBOX Text2, 10, 200, 460, 100, RGB(black), RGB(255,255,255)
FONT 3: GUI DISPLAYBOX Text3, 10, 300, 460, 100, RGB(black), RGB(255,255,255)
FONT 1: GUI DISPLAYBOX Text4, 10, 400, 460, 100, RGB(black), RGB(255,255,255)
FONT 2: GUI DISPLAYBOX Text5, 10, 500, 460, 100, RGB(black), RGB(255,255,255)
FONT 3: GUI DISPLAYBOX Text6, 10, 600, 460, 100, RGB(black), RGB(255,255,255)
CtrlVal(Text1) = "ABCDEFGHIJKLMNOPQRSTUVWXYZ~ABCDEFGHIJKLMNOPQRSTUVWXYZ~ABCDEFGHIJKLMNOPQRSTUVWXYZ"
CtrlVal(Text2) = "ABCDEFGHIJKLMNOPQRSTUVWXYZ~ABCDEFGHIJKLMNOPQRSTUVWXYZ~ABCDEFGHIJKLMNOPQRSTUVWXYZ"
CtrlVal(Text3) = "ABCDEFGHIJKLMNOPQRSTUVWXYZ~ABCDEFGHIJKLMNOPQRSTUVWXYZ~ABCDEFGHIJKLMNOPQRSTUVWXYZ"
CtrlVal(Text4) = "ABCDEFGHIJKLMNOPQRSTUVWXYZABCDEFGHIJKLMNOPQRSTUVWXYZABCDEFGHIJKLMNOPQRSTUVWXYZ"
CtrlVal(Text5) = "ABCDEFGHIJKLMNOPQRSTUVWXYZABCDEFGHIJKLMNOPQRSTUVWXYZABCDEFGHIJKLMNOPQRSTUVWXYZ"
CtrlVal(Text6) = "ABCDEFGHIJKLMNOPQRSTUVWXYZABCDEFGHIJKLMNOPQRSTUVWXYZABCDEFGHIJKLMNOPQRSTUVWXYZ"
Edited by rhiemann 2017-11-25
disco4now
Posted: 03:05am 25 Nov 2017
Hi Rico,
I see what you mean. Looks like the ~ in the string is not telling the micromite routine that the horizontal character count should be reset when it takes the newline, so even though its a multiline you are limited to total number of characters that would fit on a single line.
MSGBOX function seems to be OK, but DISPLAYBOX looks like it could be a bug.
Gerry
F4 H7FotSF4xGT
panky
Posted: 03:38am 25 Nov 2017
Rico,
Just note that although the tilde character does force a new line in DisplayBox, the manual makes no reference to using it in a DisplayBox, only in a MessageBox.
It would be nice to have the feature in a DisplayBox and as Gerry has said, it looks like just needing the character count reset at the start of the new line. One for Geoff to mull over and comment on.
Cheers,
Doug.
Posted: 04:28am 25 Nov 2017
Thanks guys, it definitely looks like a bug and is on the list for the next version (due in next month).
