Local Time 21:14 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Assembled Micromite Clock
Posted: 01:29am 06 Dec 2017
I have received an email from a reader who needs the Micromite based clock (http://geoffg.net/Micromite_GPS_Clock.html ) but cannot assemble it himself. This is the project based on a Micromite, GPS module and a two line LCD display (very simple).
If anyone can/wants to help please email me (projects@geoffg.net ) or PM me and I will put you in contact with the gentleman concerned.
GeoffEdited by Geoffg 2017-12-07
Azure
Posted: 02:35am 06 Dec 2017
I have emailed you.
Happy to bow out to more experienced MM builders and TBS forum members.
Otherwise well equipment and capable to be able to do the work.
Posted: 07:20pm 08 Dec 2017
@Geoff,
IF the 'reader' is Europe/UK based then I am happy to help. However, if they are nearer to you then I recommend someone on that side of the planet.
Posted: 10:42pm 08 Dec 2017
Ditto if they happen to be in New Zealand.
Posted: 11:30pm 08 Dec 2017
Thanks guys, the gentleman is in Australia (NSW) so it would be best to leave it for the moment and see if John (Azure) can help him.
Bill.b
Posted: 06:40am 09 Dec 2017
Where in NSW? If Newcastle region I could help.
Bill
Azure
Posted: 07:05am 09 Dec 2017
He is located not far from me, so all good.
It is a fairly straightforward build so won't be a problem.
Just trying to find out if he would prefer the Super Clock instead, which if suitable gives more functionality and will cost less to assemble. I can use a backpack kit and a cutout front panel from Silicon Chip which will labour cost in place of using perf board and cutting a front panel by hand to suit.
