Local Time 18:41 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Esp-Link built in web server and MM
SteveA
Posted: 11:22am 23 Jan 2018
Hello All,
Following on from my attempts to add a web interfaces to my micromites using esp-basic, which worked but wasn't very stable, I'm now experimenting with esp-link.
I've been able to upload a basic html page from my PC (using the 'select web page' button') to the built in server and display it, but now I'm stuck.
My MM is reading a temperature sensor and outputting the result to the serial port. Now I want to send it to esp-link, probably embedded in a html page the MM has created?
I've been googling for documentation and examples, but have drawn a blank. Has anyone got any links they could share?
Rgds
Steve
led-bloon
Posted: 08:57pm 24 Jan 2018
Can't help you with esp-link, but have you seen this topic from
the guru matherp? Especially since it contains code for
BME280 & DS18B20 devices.
Even if no use to you, a good read...
MM2: webserver with AT mode ESP8266
led
Miss you George
MikeO
Posted: 11:02pm 24 Jan 2018
Steve, Agree ESP8266 as the web server works but is not stable enough unfortunately.
ESP-Link is great as it was intended as a TCP/serial link and a few people on the forum use it a lot to communicate with the mites, I also , when I need a program link while developing. I think the Web Server development is in its early stages plus I think they are driving towards using MQTT and external servers.
I now use ESP8266 all the time using ESPbasic as the network interface to MX170/470 , then using UDP or HTTP messaging to other uMites, picromite and on windows with VB6 and more lately B4J for windows and B4A for Android Tablets and Phones. I developed a program in ESPbasic that runs on the ESP8266 which is very stable and a library for the uMites that performs the interface via the com port, which provides a 2 way command structure , plus networking UDP, HTTP, NTP for Time IOT , email etc.
Mike
Edited by MikeO 2018-01-26
Codenquilts
SteveA
Posted: 05:00pm 25 Jan 2018
Mike
I think I'm going to give ESPbasic another try. While researching alternative languages for the ESP I noticed others had problems with the ESP intermittently crashing, the one common cause seems to be power supply problems.
At the moment I'm using ESP12's mounted on small pcbs with their own 3v3 regulators and usb to serial converters, they draw their power from my computers usb port. I'm going to feed them directly from my bench power supply and see if that helps.
Mike, can I ask whether you are using the V2 or V3 branch, and how stable you find it? I don't care about the odd crash, but I was running a very simple program, reading a sensor and outputting the result on a webpage and mine were going down every hour or so!
Led, I did look at Matherp's example and I'm not ruling it out completely. But for now I like the idea of off loading the web part of my project to the ESP, because that frees up memory on the MM which means I can stick with the MX170 which is easier to solder than the smd MX470!.
MikeO
Posted: 09:32pm 25 Jan 2018
I am only using branch V3 the other is now deprecated.
I don't have power supply problems, its should draw in the order of 60-80 mA, more when its transmitting but for short bursts you won't see it. Put a cap of arround 220uF near to the module, also 100n decoupling and you should not have any issues. I tend to use the basic ESP8266 ESP-01S WiFi Serial Transceiver Module with 1MB Flash, make sure you flash the correct ESPbasic for the ammount of Flash Ram on the module as the ESPbasic image varies and some of the features are taken out. The way i use it I don't need them anyway.
I still don't recommend trying to host your web page on the module, I think the problem is string handling , there are probably memory leaks and the ram gets used up. Stick to using it to interface to your network and it works fine.
Mike
Codenquilts
