Local Time 18:41 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite eXtreme V5.04.12: Sprites etc.
Posted: 03:55pm 29 Jan 2018
Please find attached MMX V5.04.12 for 100/144 pin chips
2018-01-29_234539_MMX5.04.12.zip
and for 64-pin chips
2018-01-29_234628_MMX645.04.12.zip
Manual
2018-01-30_014224_Micromite_eXtreme_Manual.pdf
This contains a first complete implementation for sprites including layers, scrolling background, and full collision detection. It also contains the full USB keyboard implementation (US and UK layouts supported).
The sprite functionality works on VGA, all SSD1963 displays (RD pin must be connected and specified in the OPTION LCDPANEL command), and the ILI9341 display (SPI2-IN pin must be connected to the display).
Sprite and scroll functionality on the SSD1963 TFT displays is memory intensive if large sprites and scroll moves are used and users will need to code to avoid the dreaded "Error: Not enough memory"
The functionality is particularly targeted at use on VGA screens where a double buffering approach has been implemented to completely overcome screen flicker during sprite moves and screen scrolling. Performance on the VGA screen is also much better than on TFT with background scroll commands taking an average of 11mSec (177mSec for a 800x480 SSD1963 in 16-bit parallel mode)
The manual contains details of the new SPRITE command and function
The following is a simple test program that has been checked on VGA and SSD1963 (100/144-pin) and ILI9341 (64-pin)
The concept of the sprite implementation is as follows:
1. Sprites are full colour and of any size. The collision boundary is the enclosing rectangle.
2. Sprites are loaded to a specific number (1-50)
3. Sprites are displayed using the SPRITE SHOW command
4. For each SHOW command the user can select a "layer". This defaults to 1 if not specified
5. Sprites collide with sprites on the same layer, layer 0, or the screen edge
6. Layer 0 is a special case and sprites on all other layers will collide with it
7. The SCROLL commands leave sprites on all layers except layer 0 unmoved
8. Layer 0 sprites scroll with the background and this can cause collisions
9. There is no practical limit on the number of collisions caused by SHOW or SCROLL commands
10. The sprite function allows the user to fully interrogate the details of a collison
11. A SHOW command will overwrite the details of any previous collisions for that sprite
12: A SCROLL command will overwrite details of previous collisions for ALL sprites
13: To restore a screen to a previous state sprites should be removed in the opposite order to which they were written "LIFO"
If anyone would like to code up a simple game to test this properly (pong?) I'm very willing to provide as much support as needed.
Option explicit
option default NONE
memory
dim integer testrun=1
load image "tiger640"
sprite INTERRUPT collision ' specify the interrupt routine to handle collisions
sprite load #4, "apple"
sprite load #2, "apple"
sprite load #17, "apple"
' test 1 - sprites on different layers don't collide except with layer 0
sprite show 4,10,10,1
sprite show 2,50,50,2
pause 200
sprite show 17,35,30,0
pause 1000
' test 2 - single sprite overlaps the corner
sprite hide 17
sprite hide 2
sprite show 4,-10,-10
pause 1000
' test 3 - one sprite moves and hits another
sprite show 4,10,10,7
sprite show 2,100,100,7
pause 200
sprite show 2,50,50,7
pause 1000
' test 4 - collision in contact with edge
sprite hide 2
sprite hide 4
sprite show 2,-10,10,7
pause 1000
' test 5 - all layers collide with layer 0
sprite hide 2
sprite show 17, 55,25, 0
sprite show 2, 100, 10
pause 1000
' test 6 - scroll causes collision with edge of screen for layer-0 sprite
sprite hide 2
BLIT scrollv 30
pause 1000
' test 7 - scroll causes collision between sprites
BLIT scrollv -60
BLIT scrollv -60
sprite show 2,110,10,7
blit scrollv 30
pause 1000
' Close everything and check for memory leakage
sprite close 0
sprite close 4
sprite close 2
sprite close 17
clear
memory
end
' This routine demonstrates a complete interrogation of collisions
sub collision
local integer i
print "Test : ",testrun
testrun = testrun +1
if sprite(S) <> 0 then 'collision of individual sprite
print "Collision on sprite ",sprite(S) 'sprite(S) returns the sprite that moved to cause the collision
process_collision(sprite(S))
print ""
else 'collision of one or more sprites caused by background move
print "Scroll caused a total of ",sprite(C,0)," sprites to have collisions"
for i=1 to sprite(C,0)
print "Sprite ",sprite(C,0,i)
process_collision(sprite(C,0,i))
next i
print ""
endif
end sub
sub process_collision(S as integer)
local integer i ,j
print "Total of ",sprite(C,S)," collisions" 'sprite(C, #n) returns the number of current collisions
for i=1 to sprite(C,S)
j=sprite(C,S,i)
if j=100 then
print "collision with left of screen"
else if j=101 then
print "collision with top of screen"
else if j=102 then
print "collision with right of screen"
else if j=103 then
print "collision with bottom of screen"
else
print "Collision with sprite ",sprite(C,S,i) 'sprite(C, #n, #m) returns details of the mth collision
endif
next i
end sub
Edited by matherp 2018-01-31
Posted: 04:26pm 29 Jan 2018
Hi Peter,
I have loaded up this version (by-passed last two Betas) and this seems to be working really well. No issues with what I am seeing on my 'usual' monitor
Will have a play this evening with moving some Sprites around and report back with any issues.
NICE WORK yet again!
WW
Posted: 11:39pm 29 Jan 2018
Found a small bug I think.
Concerns a scrolling background (layer 0) and two sprites colliding on layers 1 and 2. Upon collision between the two sprites, something is drawn to layer 0 (where the sprites collide), resulting in a scrolling 'collision' graphic on layer 0 (these sprites should not draw anything on layer 0?).
Discovered this whilst trying a quick 'Defender' speed test (scrolling landscape with moving sprite spaceships).
Use the following code to see what I mean (press the 'A' key to collide bottom Apple into top Apple!)
Do NOT comment on code quality - I am simply doing some basic testing
cls
sprite load 2,"apple"
sprite load 3,"apple"
sprite show 3,10,100,2
y%=400
slx%=30
sly%=200
sprite show 2,slx%,sly%,1
do
d%=int(rnd(0)*3)-1
y%=y%+d%*8
if y%>460 then y%=460
if y%<350 then y%=350
box 600,y%,8,8,1,rgb(red),rgb(red)
box 0,350,8,130,1,0,0
sprite scrollh -8
i$=inkey$
if i$="," then slx%=slx%-8
if i$="." then slx%=slx%+8
if i$="a" then sly%=sly%-8
if i$="z" then sly%=sly%+8
if slx%>600 then slx%=600
if slx%<0 then slx%=0
if sly%>460 then sly%=460
if sly%<0 then sly%=0
loop
WW
Posted: 11:29am 30 Jan 2018
  Quote  Found a small bug I think.
Wasn't respecting the LIFO properly during scroll. Try this
2018-01-30_215045_MMX5.04.12.zip
2018-01-30_235005_MMX645.04.12.zip
NB there are actually two LIFOs, one for layer 1 to 50 and one for layer 0. In general layer zero sprites should always be drawn first but this isn't required as long as they do not "collide" with a non-layer-0 sprite when initially drawn or moved otherwise screen corruption will occur when the background is scrolled.
The algorithm for a scroll (this all takes place automatically) is:
remove sprites not in layer 0 in the reverse order to which they were drawn
remove layer-0 sprites in the reverse order to which they were drawn
scroll the background
redraw layer-0 sprites in the order in which they were drawn
redraw sprites not in layer 0 in the order in which they were drawn
Moving any sprite puts it back to the top of the respective LIFO. i.e. it becomes the last drawn - first removed.
The layer a sprite is on does not influence drawing order, other than layer 0
Posted: 03:47pm 30 Jan 2018
@Peter
So far so good . . . .
