panky Guru Joined: 02/10/2012 Location: AustraliaPosts: 1134
Posted: 05:39am 28 Feb 2018
I am working on an emeulation program for an old 8 bit computer and needed to simulate the memory. I need to read and write 8 bits of data at a time with an indexing pointer (the Program Counter in old 8 bit machines).
I looked at Long Strings but decided I could do it with an integer array and developed the two routines below to simulate reading from and writing to an arbitrary length memory stack from address 0 to whatever maximum is desired within the constraints of the MMs available memory.
I hope this may be of use to anyone doing anything similar.
Doug.
