Local Time 14:45 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : E100 - Pullups on Keyboard?
Posted: 04:51am 03 Mar 2018
Hello all.
I have had a question from someone asking about possible noise on the KB lines causing odd things to happen with their E100. The problem seems to have been solved by adding 4k7 pull-up resistors on the KB clock and data lines. In the schematic, they are not shown and these two lines are floating, and I am just wondering if those resistors are actually supposed to be there but were perhaps missed on the schematic?
Geoff?
Specifically, the piezo beeper used for touch clicks was squealing intermittently when it should not have been. Apparently, fitting the pull-ups to the KB lines has stopped it on the one I know about - so far.
Has anyone here who has got an E100 from me, WhiteWizzard or Silicon Chip ever had any problems with the piezo squeaking when it should not, when you have a keyboard connected to the board?
I myself have never heard of this, but it must be able to happen if someone is reporting it. At this stage, for the next revision of the board, I plan to include 4k7 pull-ups on the KB lines a-la the I2C pull-ups.
I note that page 40 of the Micromite Plus manual DOES show 4k7 resistors, but the E100 schematic(V4) does NOT show them.....
EDIT: My contact tells me this happens with the KB NOT plugged in. Just touch around the KB socket area, and the piezo squeaks. Very odd. Would LOVE to hear from any member who has had this happen to them.Edited by Grogster 2018-03-04
Posted: 06:29am 03 Mar 2018
I have not seen that and I have used the E100 a lot with a keyboard.
I put pullups into the original Maximite (if my memory is correct) but then I found that all keyboards had their own pullups built in - so I dropped them for the E100.
Weak pullups can be enabled in the PIC32. I will build a special version for your fellow to test.
Posted: 06:35am 03 Mar 2018
Hi Geoff.
Could he perhaps make use of the ChangePin Cfunction to enable the pullups on the existing firmware?
PeterB
G'Day Geof
But what happens when the KB is unplugged?
Posted: 06:54am 03 Mar 2018
  Grogster said  Could he perhaps make use of the ChangePin Cfunction to enable the pullups on the existing firmware?
Yes, much easier. It occurred to me that he has probably soldered in the pullups so there is no point building a test version anyway.
  PeterB said  But what happens when the KB is unplugged?
The internal PIC32 pullups will pull the signal lines high (which is the inactive state).
Posted: 07:01am 03 Mar 2018
I believe he has soldered in the 4k7's for now to settle things down.
Perhaps if he removes the 4k7's and runs the ChangePin Cfunction on both of the keyboard pins?
PeterB
Posted: 07:05am 03 Mar 2018
G'Day Geof
G'Day Geof.
But there are no pullups.
But there will be:)
Peter
