Local Time 14:45 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Dontronics - Make Me An Offer
donmck
Posted: 09:18pm 06 Mar 2018
About 2 years ago, I knew the day would come that I would have to shut down Dontronics, so I have worked on getting the stock levels to as close to zero as possible. But of course, I also knew I would be left with miscellaneous items. These handfuls of items are listed below. If I am lucky, they may get sold off to a wholesaler as a job lot. Barring that, they could well be dumped as rubbish.
This stock must be cleared in the next few months. Please make us a reasonable offer by sending an email to: myoffer@dontronics.com
Please let us know "The Item", "The Quantity", and your "Offer". Standard Postage will be added to each order. And if you don't ask, you will never know.
All of the items below are linked via:
https://www.shop-dontronics.com/Dontronics-Box-of-Goodies
USB-RS232 Chinese Adapter cables with FTDI Chipset.
PoUSB12 Modules with CP2102 Bridge Chipset.
26 Pin IDC Cables 10cm Female to Female.
26 Pin IDC R/A Female Headers.
26 Pin IDC R/A Male Headers.
4d-USB-5V Kit of Parts. (+5V power from USB port)
B Type USB PCB Connectors.
All gold plated connectors
Dual-64pin Female Connectors. (32x2)
Dual-64pin Male Connectors. (32x2)
Single-30-Pin Female Header Pins.
Single-30-Pin Male Header Pins.
Female Header Pins. Set of 4. (2 by 6pin, 2 by 8 pin)
Stacker Pins Set of 4.
Jumper-Wires-100mm. Set of 10 Female to Female.
Jumper-Wires-100mm. Set of 10 Male to Male.
Jumper-Wires-50mm. Set of 10 Female to Female.
USB A Male to A Female Extension Cables.
USB A Male to B Male Cables.
USB A Male to B mini 5P Male Cables.
https://www.dontronics.com
