Local Time 13:46 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Line editor to edit lines/pages in Basic
rave
Posted: 03:48pm 23 Mar 2018
Hi all,
I've added a LINEEDIT.BAS program with a LineEdit function to the MMBasic repo:
http://fruitoftheshed.com/MMBasic.Line-editor-for-interactive-editing-of-text-lines-pages-LINEEDIT-BAS.ashx?NoRedirect=1 &NS=MMBasic
I've included some examples on how to use the LineEdit function to interactively edit lines and pages of text stored in string arrays in your MMBasic 4.5 program.
For example to interactively edit a string:
a$ = "text to edit"
Do: k = LineEdit(a$): Loop Until k = 13 ' until ENTER
To edit 10 lines stored in an array:
' 10 lines of length 40
Dim a$(10) length 40
Cls
Print "Tiny edit | ESC to quit"
For row = 1 To 10
Print @(0,12*row) a$(row);Tab(11);"|"
Next row
row = 1 ' first row to edit
cur = 0 ' cursor at begin of the line
max = 40 ' max size of a$()
win = 10 ' edit in window of 10 chars
Print @(0,12*row); ' place cursor where we want to edit the line
k = LineEdit(a$(row), cur, -1, 40, 10) ' -1: get next key press
If k = 128 Then
If row > 1 Then row = row - 1 ' UP key: move up
ElseIf k = 13 Or k = 129 Then
If row < 10 Then row = row + 1 ' DOWN key: move down
EndIf
Loop Until k = 27 ' until ESC
You can even use the editor to edit while the screen is updating, for example continuously displaying the current time:
' 10 lines of length 120, edited within current screen size limits
Dim a$(10) length 120
Cls
Print " | Editor | ESC to quit"
For row = 1 To 10
Next row
' show cursor
Font 1,,1: Print @(0,12*row) Mid$(a$(row)+" ", 1, 1);Chr$(8);: Font 1,,0
Print @(0,0) Time$; ' continuously show the current time
k = Asc(Inkey$)
If k Then
Print @(0,12*row);
k = LineEdit(a$(row), cur, k, 120, MM.HRes/6) ' pass in key to edit line
If k = 128 Then ' UP key: move up
cur = 0
ElseIf k = 13 Or k = 129 Then ' DOWN key: move down
cur = 0
EndIf
EndIf
Enjoy!
- Rob
twofingers
Posted: 04:08pm 23 Mar 2018
Hi Rob,
thanks for your contribution!
Your code remainds me of my LineEdit function
and my MASKEdit$
EDIT: Both functions tested with MAXIMITES (MMBasic 4.5)!
'* MASKEdit$ V.95
'* mod of LineEdit()
'* MMBasic 4.5/Maximite
'* line editor for small strings (e.g. file names
'* time$, date$ ...)
'* MASKEdit$("12:45:56",1,"##.##.##")
'* MASKEdit$(" TEST.BAS",1," . ")
'* Special mask characters:
'* " " any ascii character
'* "#" any number(0-9)
'* "." skip char will be ignored/skipped
'* "@" numbers & letters (not yet implemented!)
'* Used functions: FindLeft,FindRight,IsNum
'* Limit:
'* The string must not exceed the width of screen
Function MaskEdit$ edText$, cursorp, edMask$
Local hpos, vpos, p, ep, keyvalue, enterPressed
Local text$,ltext$,mtext$,rtext$,C$,M$,Mask$
Local TRUE, FALSE
TRUE=1
FALSE=0
hpos=MM.HPos:vpos=MM.VPos ' save print position
text$=edText$ ' use local copy of text$ string
MaskEdit$=edText$ ' backup edText$ for Esc
enterPressed=FALSE ' Flag to EXIT the loop
escPressed=FALSE ' a Global var
ep=Len(text$) ' end pointer
C$="." ' prohibited/skipped char
p=cursorp:If Not p Then p=1 ' cursor pointer
Mask$=edMask$ ' local copy
If ep<>Len(Mask$) Then Mask$=Space$(ep)
Pause 200 ' es gibt einen Zeitfaktor fuer keyboard input buffer ~140ms
ltext$=Mid$(text$,1,p-1)
mtext$=Mid$(text$,p,1)
rtext$=Mid$(text$,p+1,ep-p)
Print @(hpos,vpos)ltext$;
Font#1,,1
Print mtext$;
Font#1
Print rtext$;
Do:keyvalue=KeyDown:Pause 50:Loop While keyvalue=0
If keyvalue=130 And p>1 Then
p=FindLeft(Mask$,C$,p) 'p=p-1 'left arrow
EndIf
If keyvalue=131 And p<ep Then 'p=p+1 'right arrow
p=FindRight(Mask$,C$,p)
EndIf
If keyvalue=13 Then
enterPressed=TRUE 'Enter
EndIf
If keyvalue=27 Then 'Esc
Print @(hpos,vpos)MaskEdit$;
escPressed=TRUE
EndIf
If keyvalue=134 Then 'Home
p=1
If Mid$(text$,p,1)=C$ Then
EndIf
EndIf
If keyvalue=135 Then 'End
p=ep
EndIf
EndIf
If keyvalue>=32 And keyvalue<127 Then 'all ASCII chars
M$= Mid$(Mask$,p,1)
If m$=" " Or (m$="#" And IsNum(Chr$(keyvalue))) Then ' num mask, only numbers
If p<ep Then
ltext$=ltext$+Chr$(keyvalue)
If Mid$(Mask$,p+1,1)=C$ Then ltext$=ltext$+Mid$(Text$,p+1,1)
rtext$=Mid$(text$,p+1)
Else
ltext$=Left$(text$,p-1)
mtext$=Chr$(keyvalue)
rtext$=""
EndIf
EndIf
ElseIf keyvalue=132 Then 'insert, when dot is on the right _and_
If mask$=" . " And p<9 Then ' mask$=" . "
mtext$=" "
ltext$=Mid$(text$,2,p-1)
EndIf
ElseIf keyvalue=127 Then 'Del
If p>1 Then
mtext$=Mid$(text$,p-1,1)
ltext$=" "+Mid$(text$,1,p-2)
Else
mtext$=" "
EndIf
EndIf
ElseIf keyvalue=8 And p>1 Then 'Bsp, delete left space
mtext$=" "
Else
If p>=ep Then p=ep
ltext$=Mid$(text$,1,p-1) 'move cursor / over write
EndIf
Font#1,,1
Print mtext$;
Font#1
Print rtext$;
text$=Left$(ltext$+mtext$+rtext$,ep)
Pause 125 ' some wait states to slow down key input
Loop While Not enterPressed And Not escPressed
If Not escPressed Then
MaskEdit$=ltext$+mtext$+rtext$
EndIf
End Function
Kind regards
MichaelEdited by twofingers 2018-03-25
The lone and ...
rave
Posted: 04:53pm 23 Mar 2018
  twofingers said   Hi Rob,
and my MASKEdit$
Nice! I like the idea of masking.
Note that you can do the same (and more ) with LineEdit by passing the key press to LineEdit with the 'key' parameter, which you can inspect and mask before calling LineEdit in the loop:
' edit string of digits
a$ = "1234"
Font 1,,1: Print Mid$(a$, 1, 1);: Font 1,,0: Print Mid$(a$, 2);Chr$(13);
cur = 0 ' LineEdit cursor to the begin of the line
k = Asc(Inkey$)
If k Then
If k < 32 Or k > 126 Or Instr("0123456789", Chr$(k)) Then
k = LineEdit(a$, cur, k)
EndIf
EndIf
Loop Until k = 13 Or k = 27 ' until ENTER or ESC
You could even make the masking dependent on the location of the string edited (which is tracked by the 'cur' parameter).
- Rob
