Local Time 12:48 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GUI DisplayBox Anomoly
panky
Posted: 11:21pm 04 Apr 2018
In playing around with DisplayBox, I came across an anomoly (don't think it's a bug, just a limitation).
In the program below, I create 5 DisplayBox's. One is a background (limited to just a strip on the left of the screen to show the issue), a heading box, 2 test boxes and a box at the bottom to go back to a previous screen.
The 2 test boxes and the back box are all overlayed with the GUI Area command to make them touch sensitive.
I initially clear the screen to white with the CLS RGB(WHITE) command.
I then set up the other boxes in order with the background box being at the lowest layer.
Touching either of the 2 test boxes hides the other using GUI HIDE, then touching the back box at the bottom restores both test boxes.
If you run the program, you will see that when you hide a DisplayBox, it knocks out the normal screen colour (set with CLS RGB(white) to black except for the area which is defined by the background box.
In short, when you HIDE a DisplayBox you get a black box in its place. The workaround is to create a full screen DisplayBox with the background colour of your choice.
panky.
' GUI Test Code
Option explicit
Option base 1
CPU 80
' Define constants for gui controls
const BB_1A = 3 ' back button area
Const BV_Area = 5 ' battery volts selection area
const BA_Area = 6 ' battery amps selection area
const BGround_Box = 8 ' full screen background
Const Head_Box = 20 ' heading
Const BV_Box = 22 ' battery voltage box
const BA_Box = 23 ' battery current box
const BB_1 = 25 ' back box
'Define variables - anything will do to test
dim BVolts = 12.8
dim BAmps = 5.5
dim BV$ = "12.78"
dim BA$ = "5.4"
dim ActivePage = 1 'default to main page
dim ReEnter = 0
cls rgb(white) ' clear screen to white
' Start of main code - initialise variables and
' other set up routines.
' initialise graphics
GUI displaybox BGround_Box,1,1,80,480,RGB(white),RGB(white)
' to show problem, the background box is limited to a strip
' on the left
Font 3,2
GUI displaybox Head_Box,1,1,797,60,RGB(black),RGB(white)
font 4
GUI Displaybox BV_Box,1,180,797,60,RGB(black),RGB(magenta)
GUI Displaybox BA_Box,1,250,797,60,RGB(black),RGB(yellow)
font 1,4
GUI Displaybox BB_1,1,420,80,60,RGB(black),RGB(white)
GUI area BV_Area,1,180,797,60 '
GUI area BA_Area,1,250,797,60 '
GUI area BB_1A,1,420,80,60 ' the back button
' preset some display boxes
ctrlval(BB_1) = "<"
' set up injterrupt routines
GUI interrupt TouchDown ' touchup not used
' preset some variables
ActivePage = 1
ReEnter = 1
Main:
do
loop while ReEnter = 0
BV$ = "Battery~Volts = "+str$(BVolts)+"V"
BA$ = "Battery Amps = "+str$(BAmps)+"A"
If ActivePage = 1 then
gui show BGround_Box,Head_Box,BV_Box,BA_Box
gui show BV_Area,BA_Area
CtrlVal(Head_Box) = "Test GUI DisplayBox Overlay"
CtrlVal(BV_Box) = BV$
CtrlVal(BA_Box) = BA$
elseif ActivePage = 2 then
gui hide Head_Box,BA_Box,BA_Area
gui show BGround_Box,BV_Box,BB_1,BB_1A
gui fcolour rgb(black),Head_Box
gui bcolour rgb(white),Head_Box
CtrlVal(Head_Box) = "Battery Voltage"
gui bcolour rgb(magenta),BV_Box
elseif ActivePage = 3 then
gui hide BV_Box,BV_Area
gui show BGround_Box,Head_Box,BA_Box,BB_1,BB_1A
CtrlVal(Head_Box) = "Battery Current"
gui bcolour rgb(yellow),BA_Box
endif
ReEnter = 0
' Interrupt service routines
Sub TouchDown
Select Case Touch(REF)
Case BV_Area
ReEnter = 1
ActivePage = 2
Print "BV Touch detected "
Case BA_Area
ReEnter = 1
ActivePage = 3
Print "BA Touch detected "
Case BB_1A
ReEnter = 1
ActivePage = 1
Print "Back button Touch detected "
Case Else
ReEnter = 0
Print "?? Touch detected "
End Select
End Sub
panky
Posted: 11:32pm 04 Apr 2018
Forgot to provide system details:
matherp 470 board with a 7" SSD1963 display.
MMBasic 5.04.09
panky.
