Local Time 11:54 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ESP8266 module type suggestions?
GoodToGo!
Posted: 10:31am 08 Apr 2018
Looking at having a play around with an ESP8266 module. But trying to work out which one to use is doing my head in.
Primarily I'm looking to connect it to my E100, but also be able to connect it various other MM's and MM+'s. (eg. E28, MM Backpack, etc)
So what do you guys suggest? What do you generally use and what are the pro's and cons of the different modules?
I'd probably stick with ESPBasic (A ported MMBasic would be reeeeeeal nice! )
Let the discussion commence!
Cheers,
GTG!
