Local Time 09:52 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Question about settick
Quazee137
Posted: 02:55pm 14 Apr 2018
settick never fires while waiting for console input.
Is that how it should be working?
Option EXPLICIT
SetTick 1000,tock,4
Dim k, count=0
Input "Waiting for tick to fire ";k
Print "main loop "; count
Sub tock
count=count+1
Print "Ding Dong ";count
End Sub
MicroBlocks
Posted: 04:46pm 14 Apr 2018
Yes.
Use inkey$ instead.
twofingers
Posted: 07:43pm 14 Apr 2018
MB is correct.
From the MMbasic manual for Maximites (v4.5)
  Quote  Up to four periodic interrupts (or regular “ticks”) with periods specified in milliseconds can be setup using the SETTICK statement. This interrupt has the lowest priority. Using the ON KEY command an interrupt can be generated whenever a key is pressed.
Interrupts can occur at any time but they are disabled during INPUT statements. If you need to get input from the keyboard while still accepting interrupts you should use the INKEY$ function or the ON KEY command.
When using interrupts the main program is completely unaffected by the interrupt activity unless a variable used by the main program is changed during the interrupt
EDIT:
I did not find the text above (about interrupts) in the manual for the Micromites (v5.4). Geoff should maybe complete that.
I think this could be a replacement for Input (and LINE INPUT) that works with SETTICK (not tested).
MichaelEdited by twofingers 2018-04-16
The lone and ...
CaptainBoing
Posted: 09:47pm 14 Apr 2018
yes.
Input is a very blunt instrument and as you have discovered, once you disappear inside it your own program loses control of things until INPUT returns.
There was a thread a little while back where a number of options were posted that give you much better functions that play nice with your code and still give you the input you require as shown in rave's link in the previous post and Peter63 function here Edited by CaptainBoing 2018-04-16
Quazee137
Posted: 04:55am 15 Apr 2018
Thanks everyone for the replies.
I looked in the 5.4 manual for the Micromites and did not see any thing
showing it would not work.
This will also apply to LINE INPUT ?
So inkey$ will do.
Quazee
Posted: 06:03am 15 Apr 2018
  twofingers said  I did not find the text above (about interrupts) in the manual for the Micromites (v5.4). Geoff should maybe complete that.
Page 40.
Quazee137
Posted: 06:32am 15 Apr 2018
Geoffg is there an updated version of the 5.4 MicroMite user manual?
Page 40 shows information on the Timing related to
PAUSE, PULSE, TIMER and SETTICK.
Quazee
Thanks. Found it on 38 and 39 under Interrupts
Edited by Quazee137 2018-04-16
CaptainBoing
Posted: 01:21pm 15 Apr 2018
  Quazee137 said
So inkey$ will do.
Not on its own. INKEY$ grabs any *single* character waiting in the buffer, if there's nothing waiting you get the empty string ""
So what you'll have to do is grab characters in a loop and build up your input data in a string variable, generally until INKEY$ returns character (13) - this is the enter key on most keyboards. Then will you have your "INPUT" string in your variable.
it isn't hard to do but if you want something canned, use one of the functions mentioned earlir.
I rarely use INPUT at all, only when I can afford to wait indefinitely in a program of for debugging etc. At any time in main threads where other things are happening in the background I always build up a string using the method above.Edited by CaptainBoing 2018-04-16
twofingers
Posted: 01:40pm 15 Apr 2018
Page 40.
Thanks Geoff. All good!
I found this
  Quote  Interrupts can occur at any time but they are disabled during INPUT statements.
on page 39 in the manual for Micromites (MM V5.04.08).
(I scanned the manual only for the occurence of SETTICK)
Michael
The lone and ...
Posted: 12:21am 16 Apr 2018
  CaptainBoing said
  Quazee137 said
So inkey$ will do.
Yes indeed. I made that mistake a few times, when I thought that the keyboard input was buffered - it isn't. (well, not past one byte it isn't)
CaptainBoing
Posted: 07:33am 16 Apr 2018
  Grogster said   ... the keyboard input was buffered - it isn't. (well, not past one byte it isn't)
good point. You have to scan the keys (I always do it in in the main loop) fairly frequently and build up a global variable, I then set a flag when char(13) received so anything that needs to know about input gets signaled there is a complete line waiting.
MicroBlocks
Posted: 08:35am 16 Apr 2018
?? Keyboard input is buffered otherwise you would miss keystrokes.
INKEY$ does not wait when there is nothing in the buffer.
I always make sure i use INKEY$ about every 200ms or faster. This will keep the user happy as longer times will be felt as being non responsive.
Posted: 08:45am 16 Apr 2018
Yes, the console input is buffered (128 characters). So, for example, the user could type in 20 characters and the next 20 calls to INKEY$ will return all 20 one by one.
Interrupts should be allowable during INPUT and LINE INPUT but it is amazingly difficult to implement so it has remained on my ToDo list for the time being.
Posted: 09:29am 16 Apr 2018
Really? That's never worked for me. If I check INKEY$ at the time I am expecting a keystroke, I get it. If I check it any other time - even if keys have been pressed, I always get back an empty string, so the code never does what it should.
IE: If I check INKEY$ inside a loop, and grab characters as they arrive, no problem.
If I don't check INKEY$ inside a loop, and just request a key from INKEY$, it is always "". I assumed this was cos at the time of the request, no key was being pressed, so you get back an empty string.
I will have a play with this command now - perhaps I was doing something else wrong at the same time.
EDIT: I am wrong. Totally wrong.
This test code does exactly what Geoff says it does. At the time I was trying to get INKEY$ to work for me, I must have been doing something wrong.
I stand corrected. Edited by Grogster 2018-04-17
