Local Time 09:52 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : EXIT DO skips line?
crez
Posted: 11:07pm 14 Apr 2018
running this under DOS mmbasic 5.0406 the line following the loop command is not executed. If a blank line is added after 'loop' then all is fine.
j=0
j=j+1
If j=10 Then Exit Do
Print "this line is skipped"
Print "execution starts here"
End
Edited by crez 2018-04-16
Chopperp
Posted: 11:19pm 14 Apr 2018
What happens if you put say PAUSE 500 in the loop?
ChopperP
crez
Posted: 11:38pm 14 Apr 2018
no change, just slower.
disco4now
Posted: 12:54am 15 Apr 2018
Known issue fixed in 5.04.08 according to the change log.
F4 H7FotSF4xGT
Posted: 02:10am 15 Apr 2018
Yes, I remember seeing this one at the time, and disco is right - it's been fixed, so please update your MMBASIC for DOS you are using.
crez
Posted: 02:42am 15 Apr 2018
Thanks, After I posted It occurred to me this might be the case.
