Local Time 07:46 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : "STICKY" CPU 80 - LIBRARY SAVE?
bowie
Posted: 10:10pm 15 May 2018
Many thanks to WhiteWizard for his heroic support in getting my E100 with SSD1963 [5"] combi up and running; and which I am now enjoying programming using MMBASIC.
However, one niggle, it is necessary to issue the command CPU 80 each time I power up in order that the display panel contents are readable.
I understand from WhiteWizard that this is being addressed in a forthcoming Firmware [?] update.
However, in the meantime, I understand that following NEW command and entering a one line program via EDIT of CPU 80 and saving by F1 and then doing LIBRARY SAVE command this should result on subsequent power-ups with this single line of code being executed. Resulting in the display being readable from the start.
However on trying this in practice it does not result in a legible display as hoped/envisaged following power cycling the module.
Please can someone advise what I am doing wrong and/or need to do.
Thank you in anticipation.
Posted: 12:02am 16 May 2018
Interesting.
I thought the 5" corruption issue had been fixed?
I know what you mean - I have had this problem myself, but the most recent FW fixed it. What version of MMBASIC do you have in your one? 5.04.08 should deal with that issue.
panky
Posted: 05:35am 16 May 2018
bowie,
Your CPU 80 command needs to be inside a subroutine called MM.STARTUP which is then saved in the library.
See page 46 of the Micromite Users Manual under Program Initialisation.
Welcome to the forum, ☺☺
panky.
Posted: 12:09pm 16 May 2018
The current V5.04.09 Beta Test version (should) have fixed the problem of corruption of the display on 5" panels.
Download it from: http://geoffg.net/micromite.html#Downloads
